Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Safely run power for dashcam?
    Pacific Paradise QLD
    Quote Originally Posted by kleung View Post
    Yeah I have - as I mentioned in my OP, my car is still under warranty so I want to avoid doing anything potentially invasive for now. Thanks all the same.
    Good to know this is possible. My trim removal kit has turned up so I might try again and see if I can't just push the cable between the A pillar trim and the windscreen.
    If you use the fuses as I did you can remove it all in 10 mins and not know it has been there.
    Meter out the two locations shown in my pic and just stick the little fuse in with the wire to the bottom and it will work perfectly.
    The fuses are $6.95 at Jaycar
    May 2010
    Melbourne, VIC
    Ok, I've finally made some progress. I did make some effort to try and remove the A-pillar trim but it just ended up being too hard. For anyone who's interested, there is a PDF with a bunch of trim removal instructions for the B6 her:
    http://vwts.ru/body/b6/b6_70.pdf
    I'm basically using Hillbilly's idea with some slight variations.
    Required tools and parts:
    • SF5125 Double mini blade fuse socket wire tap $4.95
    • PS2003 Cigarette lighter inline socket $3.95
    • Suitable additional mini fuse - probably no more than 5A since that's also the current limit of the above cigarette lighter socket.
    • A short length of wire for the negative/earth connection
    • Solder and soldering iron for soldering wires to the inline cigarette lighter socket
    • Wire cutter to take the crimp connector off the end of the wire tap.
    I've run the power for the dashcam down the driver's side A-pillar, on the windscreen side. It's very tight, but if you have some trim removal tools you can just them to jam the cable in so it will stay in place. At the bottom, I've tucked a bit of cable in under the bottom of the windscreen for a bit more stability, and then run the able along the gap between the white A-pillar trim and the dark dashboard trim. The cable just sits on the surface, but it's barely noticeable.
    From there I tuck it in under the bottom of the A-pillar trim and down into the fusebox. It's easier to do if you remove the dark plastic centre A-pillar trim - with the fuse box open, use your fingers to gently pry the top of the inner edge towards you, and it should pop out easily. then gently free the trim piece from the rubber door seal, and lift upwards to remove.
    Note that you will want to pull some cable through from the fuse box before doing the tucking around the windscreen, as the USB cable needs to run through a small gap behind a piece of plastic - you won't be able to fit the charger through if you go the other way.
    In terms of power, in my MY10.5 R36, I found an ignition-powered fuse on the third row, third from the left - a 7.5A fuse that appears to power the parking sensors (I got a message on the radio to say "OPS inoperative" when I turned the ignition on with the fuse unplugged).
    You will need the addtiional mini fuse if you are using the fuse power tap from Jaycar, because it piggybacks on an existing circuit - the existing fuse is reused for the existing circuit, and you need an additional fuse for the power tap circuit.
    For the negative wire, I plan to loosen the screw that secures the top bracket of the fuse box and just jam the negative wire behind it.
    My project still isn't quite complete - I need some fuses and some additonal wire to complete the job, but at least now the end is in sight.
    Similar information here:
    Dash Cam Power Supply installation.
    I didnt remove the connector on the wire as I have a full set of connectors and a good crimper. I just crimped a bullet onto the wire from the ciggy socket.
    You dont need to remove the A pillar cover just insert this body tool Use the middle one as its the thickest and slide it down and twist it and the cavity will widen and slide it up the screen ahead of the cable and it will slide in When you get to the bottom do the same with the gap between the bottom of the A pillar trim and the end of the dash It should fit in there and just push it further in with the tool. As I said start at the bottom and pull the cable right up to the camera and then work back down putting it in. The fuse you put in as secondary in the addafuse doesnt matter as your ciggy plug should have one in it which will be less than whatever you put in.
    Make sure where you connect the earth to is actually earth as a couple of screws in there are into plastic. I metered each one out to one of the door hinges to check and get the right one. For the earth wire If you dont have a ring to crimp on it make a circle out of the wire and run some solder around it to make a ring. Neater and wont fall out
    The fuses I show in my pics are live extras and you could have used the other ones which are less trouble and dont interfere with other things if they blow.
    All up took 40 mins to do the job.
    May 2010
    Melbourne, VIC
    My cigarette lighter socket has solder terminals, so I figured it'd be easier to just solder the wire directly. More than one way to skin a cat I suppose.
    That's a great idea, I'll try it when I get a chance. Thanks for the tip. My kit has more bits, half of which I don't understand how to use, but I do have a wedge tool like that middle one. That fat one on the left looks slightly ominous.
    Not much choice, as the addafuse won't pass current without a fuse installed. Not 100% sure I'd trust cheap Chinese ciggy chargers, TBH.
    The screw I mentioned attaches to what looks like a part of the frame. It's definitely metal, and I got 12V on my multimeter when I used it as an earth point from the fuse take-off.
    Another good tip, thanks.
    I randomly tested a few of the other spare fuse slots, and none of them gave me any voltage. The addafuse essentially gives me two separate circuits anyway, so if the cig socket circuit fuse blows, my OPS should still work, as it's on a separate fuse.
    Thanks for all your advice and tips, they're very much appreciated.
    They all do, solder 2 wires on. Power goes to the centre one and crimp the correct joiner to it
    Not much choice, as the addafuse won't pass current without a fuse installed. Not 100% sure I'd trust cheap Chinese ciggy chargers, TBH. I meant the amps wont matter a 5 or a10 Of course it wont work without one Sheeez
    The screw I mentioned attaches to what looks like a part of the frame. It's definitely metal, and I got 12V on my multimeter when I used it as an earth point from the fuse take-off. You should not use voltage readings to find earth. Use resistance and when you have a circuit it should read 0.00 Thats why I used the door hinge as its definitely part of the body and then use the other end to find a circuit.
    Never look for an earth off a power point or you could short it
    Only the top contact of the spares have power either all the time or only when the key is on
    Make sure you put the addafuse in the correct way with the wire facing down as per the pic in previous posts
    All that make sense
