Results 1 to 10 of 13
Thread: Running in a new Mechatronics unit
    Mar 2010
    Hurstville, NSW
    I've just had my mechatronics unit replaced which makes my TDI 103 drive like a different car. Thanks to Frank at Barloworld in Mascot, NSW, nice work.
    The service guys said that it might still act a bit funny for the next 2-300Km. as it adjusts to my driving style, but to just drive normally during this time.
    Does anyone know if this is true and if so should I be careful at all or drive in a particular way? I really don't want to live with a borked unit again and I'd like to make sure the new one is not mistreated but also does not get into bad habits while it adapts itself.
    Mar 2010
    I'm picking up my MY07 Passat V6 today. I hope mine doesn't have such issues with the DSG. (I do get 3 year extended warranty)
    I'm just curious, do you think the new mechatronic unit is just "better" than the original ones?
    As in, maybe they have improved the original design/spec recently and that's the reason why everyone says it drives like a whole new car when it's replaced?
    Jan 2010
    New Farm, Qld
    Mine certainly drives like a whole new car.
    Apr 2009
    Melbourne, VIC
    They're not different. Just new and work properly. No need to "run in" either. Just drive your car!
    Jan 2008
    Quote Originally Posted by jakiman View Post
    Yes, if by better you mean it has solenoids that all work.
    No, if by better you mean they have upgraded the design.
    Reset the mechatronics, tell the owner you replaced the mechatronic and they will say the same thing. It's the same when they disconnect the battery at service, you'll have people saying that dealer must have flashed the ECU as the car drives like it did when new.
    Feb 2008
    Auckland NZ
    The revised unit is better, but also drives differently.
    I had mine replace 2.5 weeks ago. It lasted only 6 days and losts its settings.
    It was reset and lasted less than 24 hours, So now driving a GTI as a loan car.
    But seriously considering giving the car back and taking the GTI instead. Even if the gas mileage is not as great as the TDI by a whole 1-1.5L/100km's.
    But yes the unit just works no drive in period as such.
    I also noticed the new unit managed 5 gear at 50km/h as apose to the old unit which would only get 5th gear around 67 km/h+
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Jan 2008
    Quote Originally Posted by glidn View Post
    You do realise that the gearbox is adaptive and learns your driving style and this takes time to do?
    It doesn't lose it's settings or drive differently but it instead starts with a pre programmed set of values which are adapted over time to suit your driving style.
    And the rest................
    Apr 2009
    Melbourne, VIC
    NO!!! The replacement units are not different other than they are new and WORK PROPERLY. They will take a while to learn your driving style though.
    Mar 2010
    reservoir, vic
    Just reading this and you talk about it learning your style... What if you have 2 drivers? Who's style does it learn....or is it controlled by who's key is used?
    Jan 2008
    Quote Originally Posted by ugg327 View Post
    It learns a combination, the key has nothing to do with it.
