Results 1 to 8 of 8
Thread: RNS510 Media Fault
    Dec 2008
    RNS510 Media Fault
    Hi All.
    Was playing music on RNS510 through SD card on the way to work this morning and all of a sudden it stopped playing. It would also not play music stored on hard drive - doesn't even display music info on screen. I tried turning off car and leave for a lengthy period and this did not rectify. Also tried factory restore (reset) in options menu to no avail.
    Radio still works fine - radio still plays even when I select "Media".
    I am thinking it is back to the dealer to get them to look at - just wondering if anyone else has encountered this problem????
    09 Passat R36 Sedan - Black, Sunroof, Dynaudio, SatNav, Kufatec Bluetooth.
    Feb 2008
    Something I tried with varying levels of success when mine froze was pulling the fuse.
    It's in the engine bay fuse compartment, not too sure which number but 19 rings a bell. The owners manual will detail it.
    Guest Guest
    Reset
    Quote Originally Posted by vwevo View Post
    Hi All.
    Try pressing the top 2 buttons on the left < > and the one on the far top right with the (i) on it 3 buttons at the same time it will do a reset on the Module it wont reset any data though screen will go blank for 30secs then if dont come back on press on button try that see how it goes
    Dec 2008
    Resetting eventually seemed to work. I will be getting checked at first service.
    Guest Guest
    There is an update for your software get them to update it
    Dec 2008
    what does the latest update give us for the RNS510 ?
    Dec 2008
    Quote Originally Posted by bennobee View Post
    There is a topic in the Car Audio & Electronics section that is talking about a firmware upgrade for RNS-510 which amongst other things (mainly cosmetic), provides voice recognition (Control). http://www.vwwatercooled.org.au/newf...ad.php?t=33636
    Certainly sounds interesting - Only problem is finding someone that has the expertise to initiate firmware upgrade and install necessary microphone - not my strong area!!!
    I might call my dealer tomorrow and see if they can arrange upgrade - although I am not hopeful.
