Results 1 to 10 of 17
Thread: Rns510 dvd playback
    Jun 2013
    Rns510 dvd playback
    Just wanted to get some advice on which software is best for creating DVD of video clips that I have. I tried ConvertXtoDVD with no luck. My clips are in mkv format.
    Thanks
    Apr 2008
    Did you try "DVD Free Studio". Very good program for all type of media.
    Web address : www.dvdvideosoft.com
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Apr 2010
    Jun 2013
    Rns510 dvd playback
    Both of these did not work for me. Im suspecting that my firmware update has caused the DVD feature to stop working. I am using Aldi discs for burning my clips. Any suggestions would be appreciated. Thanks
    May 2013
    Orange NSW
    RE: Rns510 dvd playback
    Have you tried a standard DVD in the player? Some firmwares set the reguon to something other than four. You can check if the player is ok in diagnostic mode or vcds. The players are not friendly to playing the wrong format on a disc. They also won't play videos from an SD card or mdi as far as I have tried.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Pacific Paradise QLD
    Quote Originally Posted by Purenv View Post
    Aldi discs should be Ok I have done my firmware upgrades and maps on them and havent had any trouble
    I use Wondershare video converter to do my movies as I have quite a lot I did buy it but should be available through Frostwire or similar
    ALso look for a program called DVD region + CSS Free
    It takes the protection and region code out of anything. Runs in the back ground.
    Dec 2006
    Kilsyth, VIC
    I've used freemake for years. It's quick and simple.
    As has been asked, can you plan commercial DVD's? Do the DVD's you create play in another player?
    Region coding shouldn't be an issue since discs you make yourself don't have any region.
    Quote Originally Posted by The_Hawk View Post
    Yes I realise that but was posting it for those who may want to copy some stuff to play in the car and not scratch their originals.
    Always remembering it is illegal to play a DVD, visible to the driver when moving.
    Jun 2013
    Original DVDs work fine. Just tried my little ones Elmo dvd. Will try some of the recommend software and get back with to you guys inregards the outcome. Thanks
    Jun 2013
    The DVDs I create work fine else where but not in the car. Just tried Wondershare video converter and no luck. Its odd that it can play originals but not ones that I make. How do I check what format my RNS plays. I assume it was PAL.
