Results 1 to 10 of 18
Thread: rns 510 video in motion
    Dec 2012
    adelaide, south australia
    hi all
    tried a permanent vim unlock however cant get it to work
    Has any one any tips or tricks or wanna do it for me?
    Thanks
    Aug 2007
    Adelaide hills, SA
    Re: rns 510 video in motion
    I can do it for you without removing the unit, over obd2 port.
    Sent from my GT-N8000
    Aus
    Quote Originally Posted by levendi001 View Post
    hi all
    Thanks
    Download the custom firmware from kamold available here:
    New firmware for RNS510/Columbus versions 4120 and 5210 make sure you read the warnings about your RNS version first
    Works wonderfully on mine.
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
    Apr 2010
    You can do it without upgrading firmware by burning the contents of one of these ISO images to CD at the slowest write speed possible:
    https://docs.google.com/folder/d/0B4...J1MlQtRms/edit
    There's also a CD to disable VIM.
    Dec 2012
    thanks all, downloaded to cd and unlocked it. so excited it WORKS
    cheers
    Dec 2012
    Melbourne, VIC
    Hi Levendi001, there are quite a few replies with different threads here, which one did you download exactly??
    Dec 2012
    hi there
    manage to download this file and then burned it to cd- insert into rns will read not valid format just wait and will load
    https://docs.google.com/file/d/0B55T...it?hl=it&pli=1
    hope this helps
    May 2010
    Melbourne, VIC
    hi all
    Thanks
    Just a heads up for those applying this mod - having video visible while in motion may be in violation of the road rules in your state. There does seem to be a bit of ambiguity for some states though. I've looked at the National, NSW, Victorian and SA road rules. They all start off the same:
    299 Television receivers and visual display units in
    motor vehicles
    (1) A driver must not drive a motor vehicle that has a television
    receiver or visual display unit in or on the vehicle operating
    while the vehicle is moving, or is stationary but not parked,
    if any part of the image on the screen:
    (a) is visible to the driver from the normal driving position;
    but they differ in the 'exceptions' clauses. Victoria, SA and the national road rules state:
    (2) This rule does not apply to the driver if:
    (b) the vehicle is not a motor bike and the visual display unit is, or is part of, a driver’s aid and either –
    (i) is an integrated part of the vehicle design;
    A "driver's aid" is defined in the road rules as inclusive of:
    1 Closed-circuit television security cameras.
    2 Dispatch systems.
    3 Navigational or intelligent highway and vehicle system equipment.
    4 Rearview screens.
    5 Ticket-issuing machines.
    6 Vehicle monitoring devices.
    I would consider the RNS510 to be a visual display unit that is part of a driver's aid and is an integrated part of the vehicle design. So using that interpretation, in theory, it should be legal to enable VIM in Victoria and SA, as the rules only specify that the unit is CAPABLE of being a driver's aid, not that the exception only applies while it is being used as a driver's aid.
    However, the wording in NSW's road rules is more specific:
    (b) the visual display unit is used as a driver’s aid and either:
    (i) is an integrated part of the vehicle design,
    I would interpret the NSW rules to mean that the exception only applies when the VDU is actively being used as a driver's aid (ie displaying climatronic information, stereo information, reversing camera image/sensors or satnav information)
    Is this a loophole for Vic and SA drivers with RNS510s?
    Disclaimer: IANAL, and my interpretation of the road rules may not be the right one.
    Sep 2012
    I would not take this advice as good advice on the law. It is not performing the function of a drivers aid whilst video other than are reverse camera are playing. There are very logical reason such as trucks that pick up your rubbish that have video screens on whilst in motion and they are considered vehicle monitor devices...
