Along the same lines as Snail Styles advice, I'd revert back to the halogens (you don't even have to fit them into the housings) and see what happens. Make sure you cycle both the ignition & headlight switch back to OFF.
If that works then it's probably a ballast issue.
There is a slight possibility that the "canbus friendly" ballast has damaged the BCM but usually the wipers & (possibly horn??) play up at the same time.
I run "canbus friendly" on my Octavia (due to ignorance at the time) and I coded them in as well. I'm told it's a ticking time bomb but it's been good for 5 years so maybe not.
If I was buying again I'd buy without a resistor & code them.
If you have damaged a module it might be worth reading the codes.
my wipers are fine, im going to a dealer tomorrow since they gave me 3 months full warranty when i bought the car , if they cant fix it il go from there
Send me a PM with the vin# and i'll give you an idea what to look for.
Volks Handy
Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
10 years experience working for Audi/VW/Skoda
Now in Perth NOR, Western Australia.
Well I went to the dealership and they checked it and it said it had something to do with the ignition , gutta wait for some senior technician to come back from his holiday until they zna fix it , you guys know any ideas what it could be?
while im waiting, i was thinking of getting a wire and connecting the power from the left headlight dipped beam to the right one which isnt working,that way when the headlights turn on the right will as well? could anything bad occur from this?
Power supply is direct from the power supply module. So if you have no power at the connector, you need to check back at the brown 52 pin connector under the dash, pin number 52 with a yellow wire and a purple trace.
If there is nothing out of the module, and power + earth supplies to it test fine, then your most likely looking at a new control module.
Volks Handy
well if thats the case good thing i got the 3 month full warranty!
