Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 90
Thread: Reversing Camera for R36 Wagon
  1. #51
    Jun 2009
    Quote Originally Posted by hellfire View Post
    Interesting. I remember seeing somewhere else a picture of the OPS and RVC on the same screen. Yours appears on different screens. Is this a setting? How do you toggle between the 2?
    Yep, upgrade the software and the plan view showing the sensors comes up in that empty box on the left hand panel in this image. No need then to switch between views. I did it to mine, much better
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
  2. #52
    Apr 2010
    Singapore
    I take it you mean the firmware of the RNS510? Do you know if all this is gonna work on the RCD510?
  3. #53
    Mar 2010
    Quote Originally Posted by apom View Post
    That sounds like the way to go. Is the upgrade something easy to do?
    MY10 Silver R36 Wagon
    VW Classifieds Username - VWC-adrock
  4. #54
    Jun 2009
    that would be it! Not sure if this is the same procedure on the RCD510. Send a PM to Swallowtail, he is the master of these units in knowing all the ins and outs! (He upgraded mine for me!)
  5. #55
    Apr 2010
    Singapore
    Thanks pal!
    Calling Swallowtail....
  6. #56
    Oct 2009
    Cairns, Qld
    Ok, I read right thru the thread and would now like to know where all the necessary stuff can be purchased. I have a R36 Sedan with RNS510 and OPS and would like to aid a camera. Al help appreciated.
    cheers
    Murray
  7. #57
    Mar 2010
    Hi Murray,
    I had all of mine done by an installer on Melb so am unsure of where he sourced the parts, etc.. I'm pretty sure though that the boot handle is different in the sedan to the wagon. Sorry I couldn't help you out.
  8. #58
    Apr 2009
    Melbourne, VIC
    the boot handle/latch on the sedan is the VW logo...
  9. #59
    Jul 2009
    Singapoe, Singapore
    hi!
    I enabled via VAGCOM for a mate here:
    YouTube - Passat CC Reverse Camera Emblem RNS510
    Although the video is showing a Passat CC with the original VW emblem RVC, I've also tested successfully on a setup similar to adrock
  10. #60
    Mar 2010
    Quote Originally Posted by hannson View Post
    hi!
    Hey hannson,
    I'm loving how the OPS displays on the left hand side when the camera is engaged. I'm definitely going to see about getting that happening somehow. I noticed though that it also has the guidance lines. I'm assuming that CC actually came with the RVC as factory as I didn't think you could get those displaying aftermarket unless you spend some big $$?
