I take it you mean the firmware of the RNS510? Do you know if all this is gonna work on the RCD510?
Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
Thanks pal!
Calling Swallowtail....
Ok, I read right thru the thread and would now like to know where all the necessary stuff can be purchased. I have a R36 Sedan with RNS510 and OPS and would like to aid a camera. Al help appreciated.
cheers
Murray
Hi Murray,
I had all of mine done by an installer on Melb so am unsure of where he sourced the parts, etc.. I'm pretty sure though that the boot handle is different in the sedan to the wagon. Sorry I couldn't help you out.
MY10 Silver R36 Wagon
VW Classifieds Username - VWC-adrock
the boot handle/latch on the sedan is the VW logo...
hi!
I enabled via VAGCOM for a mate here:
YouTube - Passat CC Reverse Camera Emblem RNS510
Although the video is showing a Passat CC with the original VW emblem RVC, I've also tested successfully on a setup similar to adrock
Hey hannson,
I'm loving how the OPS displays on the left hand side when the camera is engaged. I'm definitely going to see about getting that happening somehow. I noticed though that it also has the guidance lines. I'm assuming that CC actually came with the RVC as factory as I didn't think you could get those displaying aftermarket unless you spend some big $$?
