![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
geoffp
OK,
Rob from Auspack Electronics replied to my query.
SENT
Message: Hi,
I have a 2010 Mark VI Passat Wagon.
Can you tell me if the Passat RVC on your web site provides a composite or
RGB signal.
I am trying to work out if I need the VW controller (required with a
composite signal) to connect into my RNS-510 when I order the camera.
Many thanks,
Geoff.
RECEIVED
Hello Geoff
The camera produces a composite video output (RCA connector)
The are two types available a CMOS type and a CCD type.
Both are in stock, the CMOS type is 85.00 and the CCD type is 135.00
The CCD is far superior in the dark and provides an overall better
picture.
Kind regards
Rob.
Rob attached a .pdf with some camera comparison shots as well.
I will convert to images and post links a bit later today (hopefully).
So, based on the above I will need a VW controller which should then give me the moving steering angle lines.
I am going to discuss the above with Volkspower this week as well.
This is a good thread, if everyone dumps the knowledge here it will make things a bit easier for anyone wanting an RVC (especially one the Wagons).
The dealer I bought my Passat from even rang me inquiring who was doing my RVC install!!
