BUMP!
Anyone had any luck with this? My car is a B7, but interior is pretty much identical to B6 anyway. The lack of footwell lights annoys me, even my Golf had this feature. Are there OEM parts available for a retrofit?
Hi all,
Has anyone tried to retrofit the courtesy footwell lights on a B6?
I'd like to install courtesy lights on the bottom of the doors also. I think they may be called the courtesy gutter lights?
Just wondering if the wires are already inside the door somewhere and all i have to do is connect the globes to it or do i have run the wires all the way to the Comfort Control Module.
this is what i'm talking about.
Courtesy Footwell Light
---------- Post added at 12:23 PM ---------- Previous post was at 01:08 AM ----------
It's ok i've found this
Adding Door Warning Lights to the Volkswagen Golf and Jetta – Front | my-gti.com
So the question is....where is the cheapest place to buy these light assemblies from in Oz?
BUMP!
Door courtesy lights
Bold-Sport.com :: Passat B7
nice kit.. also if you want to purchase the parts and diy then you could following the guidelines for golf.. i think that the parts are the same.
hrm, seems that oem parts are very expensive so over $100 just for the reflectors alone, then you need the repair wires and connectors and cloth tape.
Cheers for the link - hadn't heard of Bold Sport before. Will pick up the parts and give it a go.
Yeah, the part numbers that i was looking at are for another model i think. Passat ones must be 1/2 the price of golf ones. but they would get them in bulk along with the connecters and wires etc. I will have to pick up a set. au delivered vehicles don't get these lights on any model passat. golf had them early 2005 then they got deleted.
I bought them for my MK 6 Golf from Bold Sport, quick delivery and no problems.
Edit: Cheaper here
http://www.aliexpress.com/store/prod...468101360.html
My kit arrived from Bold Sport, just got to wait until I have a full day spare to install it all neatly.
This thread may be helpful for wire locations:
VWVortex.com - Passat Rear Ambient Footwell Lights Mod
The link says all the info about which pins to use, I'll just have to be careful and take my time to get it right
http://www.bold-sport.com/store/inde...product_id=131
I figure what it's saying is connect the power pin to pin 7 on plug B where the fuse box is and connect the ground wire anywhere that I can ground it properly. It's got one of those ring shaped connectors on the ground wire, so I'll just find a suitable bolt/screw to use for that.
