36psi minimum.
What would be recommended psi for pilot sport 3 on passat tdi sedan ?
Sent from my GT-I9305 using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
36psi minimum.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Checkout inside your fuel lid. I normally go around 270 kpa for the PS3's on our TDI (without any load or passengers in the car).
When using an electronic pump at any local service station, I can hit the "Unit of Measure" [i], button to get kpa.
The pressures mentioned on the placard are a little too conservative as far as good tyre life goes.
'01 Beetle 2.0
Yeah, I'd be aiming for the high 30s.
'01 Beetle 2.0
It is a personal choice. It depends on the type / feel of ride you prefer. Most tyre places suggest a minimum of 36psi all round for an unladen car for suburban driving. Higher if the car is loaded or travelling at sustained high speeds.
The tyre placard is a good place to start.
I personally use 38psi for the burbs.
OK cool, 270kpa ~= 39psi. So the OP should aim for around 36 - 39psi for their PS3's?
I use 38 psi for bridgstone before...maybe ps3 different...just qussing...
Don't forget hot/warm tyres will give you a higher reading than cool ones & usually servo gauges have had a tough life & are unreliable...
