Results 1 to 10 of 11
Thread: Recommended psi for tyre
    Jan 2013
    What would be recommended psi for pilot sport 3 on passat tdi sedan ?
    Sent from my GT-I9305 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Dec 2008
    Sydney/Canberra
    36psi minimum.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2014
    Checkout inside your fuel lid. I normally go around 270 kpa for the PS3's on our TDI (without any load or passengers in the car).
    When using an electronic pump at any local service station, I can hit the "Unit of Measure" [i], button to get kpa.
    Dec 2008
    Sydney/Canberra
    The pressures mentioned on the placard are a little too conservative as far as good tyre life goes.
    '01 Beetle 2.0
    Feb 2014
    Quote Originally Posted by Umai Naa!! View Post
    Really? Is it better to go a little higher? I always thought they seem a bit soft.
    Dec 2008
    Sydney/Canberra
    Yeah, I'd be aiming for the high 30s.
    '01 Beetle 2.0
    Aug 2012
    Perth WA
    It is a personal choice. It depends on the type / feel of ride you prefer. Most tyre places suggest a minimum of 36psi all round for an unladen car for suburban driving. Higher if the car is loaded or travelling at sustained high speeds.
    The tyre placard is a good place to start.
    I personally use 38psi for the burbs.
    Feb 2014
    OK cool, 270kpa ~= 39psi. So the OP should aim for around 36 - 39psi for their PS3's?
    Jan 2013
    I use 38 psi for bridgstone before...maybe ps3 different...just qussing...
    Arrawarra
    Don't forget hot/warm tyres will give you a higher reading than cool ones & usually servo gauges have had a tough life & are unreliable...
