Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: RE: Safety Warning Traingle
  1. #51
    Jan 2008
    have you looked at the ones in the safety section at Bunnings? $10 in a red plastic sleeve. Not sure about Passat but it fits the holder in the Octavia perfectly.
    But the one from bunnings is absolute rubbish, doesn't meet any standards (not even the Australian standard 3790 which is a joke) and will be useless in an emergency.
    A warning triangle that meets the UN-ECE 27R requirements will have
    - An inner florescent triangle for use during the day with the reflector for night time use.
    - Watertight reflector, the cheap ones are not watertight and as soon as water enters the area behind the reflector they stop working - 100%.
    - A design that allows it to remain standing even with trucks passing them, the cheap ones fall and this renders them useless or even a hazard.
    BMW sell some cheap ones for under $20 in a plastic bag that meet all the requirements and for around $35 you get a plastic case.
  2. #52
    Erskineville, NSW
    Quote Originally Posted by Maverick View Post
    I'm not quite sure what you mean by "useless in an emergency". if your life is hinging on a warning triangle I think that there is something wrong.
    Mine looks like this and I think for $10 and with a usage rate of once per 10 years or so, I'm happy to chuck it out after every use. It's imported by Whites Wires (who seem reputable) and has the E in a circle mark on it.
    Check?
    Quite probably. If it rains I'll get a new one
    Four legs at the corners, each 400mm long. Looks stable to me
    I guess if it was something you know would be used regularly, then a 350% premium would be worth the spend, but you know how my mind works...... "Even a cheap crappy triangle is an improvement over what most people have in their cars."
  3. #53
    Jan 2008
    The purpose of the warning triangle is to warn traffic that there is a hazard ahead, it's pointless if when you need to rely on one if it blows over and ends up creating a hazard itself.
    If that's the one with a code of 14580 it's different to the one that I saw there, JHP says it's pretty good for the price - CALLS FOR IMPROVED ROADSIDE SAFETY : NBN
    And some more info from him - News - Owner//Driver
  4. #54
    Queensland, Australia
    Pfft! What do you want one of these for - you own a VW - it won't break down! Have faith brethren!
    Tony.
    2008 Passat 125TDI DSG, Leather.
    2007 MkV Golf GTI - APR, 188kW, Leather, Manual.
  5. #55
    Erskineville, NSW
    maybe next time you could clarify information before dissing somebodies suggestion. You are so much like my missus
  6. #56
    May 2007
    Ok so went to VW today and ordered the following; 000093055K.
    Turns out this was the original one they sold me (incorrectley) when I had my sedan.
    Will wait to oick up mid next week.
  7. #57
    May 2007
    Quote Originally Posted by ope126 View Post
    Ok, so it seems that we have got it wrong again!
    Part No: 000093055K does not fit in the alcove as it is too high.
    I have now been told the correct Part No: 1Y0093055 is not available to be ordered in Australia, Euro market only.
    So once again my question to all with agons, what Safety Triangle Part Numbers do you have?!
  8. #58
    Apr 2010
    Hi ope126,
    The triangle in mine has 2 different part numbers: p/n 8D9 860 251 B under audi and vw logos on the main case, and p/n27R03566 under a GEKA logo on the lid of the case.
    MY17 Passat Alltrack Wolfsburg, Indium Grey, Sunroof
  9. #59
    May 2007
    Quote Originally Posted by Gazza View Post
    Hi ope126,
    Thanks Gazza for your help, much appreciated!!!
    Will see what I come up with, actually sounds like an Audi Part Number.
  10. #60
    May 2007
    Looks liek we have found a winner; World Impex, Inc. - Search Results
