Results 1 to 10 of 10
Thread: RCD-510 + 32 GB sd card..
    Jan 2013
    hey,
    I have weird problem with my RCD-510... I do not if this common so, i want to ask you guys..
    If I transfer 200 or more mp3 songs to my sd card rcd-510 can play (and see) only around 150......
    How to fix this issue..?
    Regards
    Running (i beleive 2009 software) and 9w7 Bluetooth ..
    vw 2009 passat td sedan
    Re: RCD-510 + 32 GB sd card..
    There are limitations to how deep the folder structure can be. Details are in the manual. Can't remember off my head.
    Another thing to check is if your card is genuinely 32gb. There are heaps of counterfeit cards that are marked as 32gb and appear to your computer as 32gb but are in actuality 4gb cards. Check Google for details. I bought one once. Easy to test.
    Sent from my HTC One X using Tapatalk 2
    Jan 2013
    I am using Kingston ultimate X 32 gb.. Yes, this is original. regarding limitation, RCD-510 should see at least 2 GB...
    Pacific Paradise QLD
    Quote Originally Posted by saint70 View Post
    I have 18 gig of music on a card, About 4000 MP3's and my RNS will play them either off the card or the HDD
    You should copy TRACKS only NOT ALBUMS to the root directory of the card and it will then see all of them.
    My card is an ALDI BAUM and it works OK
    Jan 2013
    Thank you for your suggestion...I will try this one
    Apr 2010
    Try separating songs into different folders - there's a limit as to how many tracks per folder can be displayed (unit would be too slow otherwise).
    Jan 2013
    yes, I did that before...yes, unit will be really slow.
    I jkust trying NTFS partition instead FAT...and also, i am going to copy only tracks..
    thatnk you for your suggestion too
    Can't read ntfs
    Jan 2013
    ops...did not know ...gonna change
    Mar 2013
    Melbourne, Australia
    Any progress on this? I'm about to buy a Passat with the RCD 510 and no MDI, so keen to see if the SD card slot can take more than 2GB to replace the iPod interface...
    E
