Well that's a lesson to be learnt in future we should all demand that an original windscreen be installed by VW
Hi everyone,
I've found quite a few posts around various forums about this but thought I'd ask if anyone had first hand info as I'm getting the run around by AAMI (my insurer) and Windscreens Obrien (the repairer).
Basically long story short, large crack in 2008 R36 windscreen, called AAMI, they referred me to Windscreens Obrien, windscreen replaced and now rain sensor isn't working and auto lights are always on.
Obrien then pulled the sensor apart again and gave me the spiel that they don't disconnect them, put the keys in an aluminium foil bag and don't start the car with the windscreen out so it shouldn't need to be reset.
I've connected my VCDS cable and attempted to clear the error code (004 - No signal / Fault Status 01100100) and it comes back straight away. Went back to Windscreens Obrien and they've advised that as it's not a genuine windscreen it may need to be recalibrated, can't find any info in the VCDS to calibrate or even adjust the sensitivity so I've booked it into VW.
Has this happened to anyone before and is there a fix?
Thanks in advance for any advice.
Nathan
I questioned AAMI about it and they said under their terms and conditions "If a non-genuine item is available, it'll be used in direct replacement of the genuine glass".
My argument was that I took the car in fully functioning and with genuine glass all around and it came out not working and with an inferior windscreen, at which point they then referred back to the T&C's.
Definitely take it as a warning everyone..
AAMI are notorious for using non genuine parts with their smash repairs and forcing down the repair quote of the repairers. As a result they hate AAMI.
I would firmly but politely ask AAMI in writing to sort out this problem as you went to their recommended repairer and inform them that if there is no satisfactory repair, you will seek the assistance of your states consumer protection.
Good luck
Thanks for the advice. I've been documenting all correspondence with AAMI and Obrien 'just incase' it gets to that.
I agree! stay away from AAMI! My once bad experience through an AAMI repairer: They had the car a few days and news came from AAMI that my RNS got stolen from the dash and damaged it while at the repairer!!. All the hassle of police reports, finger print white powders etc!!! Then my car still had to be repaired by them again which took 1mth for a simple <1 week job. Piss off workmanship as well!
Learnt the bad way! Nvr again. I am very happy with AI Insurance with choice repairer!
Update: AI insurance do not provide choice repairer anymore as according to the latest PDS. I'm swapping to NRMA which comes out cheaper for my renewal.
Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
Ive seen it quite a few times...the sensor gets pulled from the screen and swapped onto the new screen...the sensor just doesnt like it. .I would say 1 out of 10 sensors need replacing after being moved.
DARKHORSE DEVELOPMENTS
BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. 0420839266
BRISBANE/GOLDCOAST/IPSWICH
www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
you aren't lucky with aami. I had the dodgiest repair with their 'recommended repairer'.
The actual text from the current PDS is:
and specifically relating to glass repairs:When we authorise repairs to your car we will:
- ensure the repair work is properly carried out;
- use new parts or parts that are consistent with the age or condition of your car, including non-original equipment parts. These parts will meet available manufacturers’ technical specifications and/or applicable Australian Design Rules;
- only use new original equipment parts if your car is under the manufacturer’s standard new car warranty period (but not under any extended dealer/manufacturer warranty period).
So if they're going to cite the Ts and Cs to you, you should beat them over the head with the first two conditions, which is that the repairs be properly carried out, and/or that the replacement parts do not meet the manufacturer's tech specs (given that the rain sensor no longer works).For windscreen or window glass repairs, we might use glass that is different from the original but the
glass and repairs will meet Australian Design Rules.
Thanks for all the feedback, it's really appreciated. Guess it's just a matter of waiting until Tuesday now and see what VW say, kind of hoping Obrien have killed the sensor just so I can stick it to the smug workshop manager..
