Originally Posted by
passat08
found out probably tint doesnt help either cause aerial is the back window
If it is a metallic tint then that may contribute to the problem by blocking the radio waves (i.e. lower/no signal coming to the antenna stuck onto the inside of the rear glass, again this would be direction dependent: better reception driving away from the transmitter and worse driving towards it - is this what you are seeing???) - did read up on this before I tinted my car/s and to a certain extent it depends on the metallic tint (and how much radio wave blocking metal they use in it), was non-issue for me as ended up at that time getting a car with external antenna on back of roof.
If it is a non-metallic tint then less likely to be an issue re radio waves being blocked by the film (may be due to a poor connection somewhere along the line from the antenna to the head unit?).
Re my Passat wagon and radio reception - have not noticed any issues . . . antennas in shark-fin
MY12.5 B7 Passat Wagon : : TDI Highline : : Icelandic Grey : : black leather interior
sports pack | sat-nav | panoramic glass roof | adaptive cruise control | driver/lane assist | bi-xenons/LEDs | RVC plus | auto-park | auto tailgate | tow-bar | mud-flaps | sill-protection | wood trim - ||| - Lakin plate mounts | tinted | Opti-Coat | LED reverse lights | bright white driving lights + turn lights (LEDs were too 'dim')
