Results 1 to 3 of 3
Thread: Radiator fan running after switchoff
    Mar 2008
    North Lake WA
    Hi, my MY13 Alltrack sporadically runs the radiator fans full tilt after switchoff , and for no apparent reason, as I am not driving any different at the time. Will run for a number of minutes and go off.
    Not worried, more puzzled as it doesn't appear to be weather related either ( even after a very short run on a cold day).
    The frequency is quite low, maybe once or twice a month when I do 2500km a month! Most trips are freeway or city roads.
    Sent from my Nexus 7 using Tapatalk 4
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    It sounds like an interrupted DPF regen. I believe that when a regen is underway the engine runs richer and hotter than normal, if we turn off the engine during this process the fan(s) come on and do their thing to cool everything down. It has happened to me a few times in 2 years/ 75,000km.
    2012 MK6 GTD CW DSG Seattle's 3M Black Tint, Michelin PS3's.
    Mar 2013
    Brisbane QLD
    Above is correct and true....VDUB
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
