I had an 06 GTI and it works via rotation method via abs sensors etc so makes sense the R36 may be the same.
US model passats do however use valve stem sensors
If the sensor measures rotational differences as a means of determining whether the tyres are low, then how would it account for corners, curves, wheel spin etc? I am sure that an average over a longish distance would be also fraught with danger as this would not necessarily be accurate especially, if you are travelling in a loop or arc.
If you are driving on the M7, for arguments sake, it basically arcs around the outskirts of Sydney and would constantly say that the inner tyres were travelling less than the outer tyres and would therefore register a difference.
I've seen the valves in person, when changing to new wheels myself, and they are a big unit - not cheap to replace / buy either.
The main part sits on the inside of the rim, so the valve looks pretty normal from the outside.
Problems arise with aftermarket wheels when their shape (on the inside) does not allow the big sensing unit to sit flush (and thus airtight). Its a matter of trial and error.
You have to be prepared to ditch the TPMS if the wheels you choose are the wrong shape or somehow don't have room on the inside.
Lots of tyre places are very badly educated (if at all) on the subject of these fancy valves. You have to be very careful because these things are easily damaged - the threads especially.
Make sure your tyre fitter at least has seen a few TPMS systems before.
RIP! 2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
