HI all,
just wondering all u guys that changed ur wheels, how u go with the pressure monitoring system. Was it ok to change sensors over??If so where are those sensors. I think it says its in the valves in the manual.
Thanks for ur help.
HI all,
Thanks for ur help.
2009 R36 Black Sedan.
Good point, I hadn't thought of that!
My wheels get changed to 19's next week and I'll look into it and post findings if no-one else has an answer?
Mini Cooper S Chilli- when I can pry the keys
Carbon Steel GTi 19" BE by Breyton,LED tail lights, NEW 8" Nav !
Facelift Daytona Grey A5 Sportback, S-line 19" Titanium Rotors
Well there's a number of people (myself included) that have been informed that the pressure monitoring system isn't in the valves at all. So I'd be careful.
It's a little black box attached to the valve.
Should have taken a photo when I was getting the new tyres fitted...
Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
Not true, the TPMS will tell you if there is a problem even when your stationary.
With the onset of Winter and lower tyre pressures we used to get notified about low pressure when we started car in the morning.
That's exactly what I have been told too. Not just by the dealer. I haven't read anything in the manual about the TPMS though (doesn't mean it's not in there somewhere). Makes sense too because with a valve system you'd be able to see the actual pressures of the tyres in the MFD I would think.
There are no problems in swapping them over to a new rim, just that you need to have a rim that allows for the fitment of this type of valve. There needs to be enough room around the valve for the nut and washer to clamp it down and enough room on the inside of the rim for the sensor to fit. The original VW rims have a small flat plane on the inside of the rim for the sensor to sit on, but I am not too sure whether this is actually required for the sensor.
You also need to get a new rubber gasket set for the valves as they are destroyed when removing them from the original rim. Get a set ordered in from your VW dealer and take them with you to the tyre fitting place for fitting when you swap them over.
