Just want to add that we don't get rid of knock control or anything like that.
If you were to throw in 91 unleaded even on our tune, when you put your foot down the power delivery will be severely hampered as the ECU will correct the timing big time, but even in this situation no damage would be done to the car.
Dyno'ing the car doesn't show how safe a tune is a to run; in an N/A car we can't modify how much air is being drawn in by the engine; for improvements in air mass intake, you need to look into exhaust/downpipe and intake upgrades.
The focus is on using the amount of air mechanically induced by the engine in the most effective manner possible. Yes a dyno run shows the power developed at the wheels, but is not an indication of how "safe" the car is to drive.
If anything, a dyno run can be used to look at how aggressive the boost is being commanded on a turbo car; if the torque is spiking very high, etc. then you know that's bad for the turbo.
In an N/A car, even if our program called for 40 deg BTDC of ignition timing, the ECU simply would not let you do it as it the knock voltage would suddenly rise and the ECU would cut the timing heavily. On a dyno curve you would see this as flat spots or dips in power. But again, no damage done.
Fuelling is a different matter, however our tune does not lean out the fuel mixture at full throttle for whoever is concerned about that. We have removed some of the fuelling at part throttle/low loads but this is for around-town fuel efficiency reasons.
On a personal note, I love the R36 as it is a fast car in my opinion whilst providing a luxury ride and all the toys you need. From a marketing point of view, it is difficult to sell an R36 tune as the gains are limited, but I would like the feeling of knowing that the engine is running at its peak, even if it only shaves a couple of tenths off a quarter mile run (not that many R36 owners would be doing that). The overall feel/character of the engine combined with fuel economy is, I believe, definitely worth it for the $730 asking price.
I was and still am away this weekend (went to another trackday at Winton) so R36 testing has been delayed slightly but will update everyone when more information is available.
