Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: R36 wanted for new ECU tune testing
  1. #31
    Apr 2011
    I find it interesting that a lot of people seem to think they know more about a product, or a process than the person who is doing it/selling it..
    I'd pay $700 for 15kw any day of the week on an atmo car.
    That's cheap as dirt. Chip tuning, FI or NA is the cheapest horsepower adder you'll find.
    Put a $1300.00 exhaust on and see if you get 15kw! Not even a Akraprovic Ti exhaust worth 3k will give you 15kw.
    All the best to you, John.
    I know about tuning (as opposed to thinking I know about tuning, or thinking I know what someone else knows then making assumptions and getting it wrong ) because, well, I can tune. I tuned my own car, and have tuned others' cars. I have an Evo 8 as well as my R36, so it also allows me a comparison between the Evo, which is reasonably fast, to the R36, which is not fast, and I can say from that comparison, for me, that the R36 is not worth spending a cent on in terms of tuning - even tuned you're in the mid 13's for the quarter. You'd need forced induction to make an R36 fast. 15kw at the engine (from the first post here - claims the tune produces 235kw) on a car that weighs 1.7 tonnes is pretty minimal.
    One of my issues, if you read back a couple of posts, was that these tuners are close-lipped about how they tune, and most seem to indicate at the engine power figures. Seems this is common with Audi and VW tuners, I'm not singling this guy out. I want more clear information because I come from a tuning scene where we use dyno tuning, and gains are accurately discussed in terms of KW at the wheels on a certain dyno using a certain measurement mode (math model). Enough with the talk already, tune a car, dyno it and post the results - surely that's not too hard to do. He has back calculated using estimated drive train losses to get the 235kw at the engine figure, unless he engine dyno'd the car. I'd like to know which method he used, and if i was dyno'd and back calculated what are the specifics of the dyno used - this along with the dyno measurement mode should be provided when making power claims, and this is what I'm used to. Also if it was calculated from an at the wheels figure what % drivetrain loss was used and how was this established? At the wheels figures are commonplace in japanese tuning, no idea why german tuners use predominantly at the engine figures.
    @johnw - I have seen cars with mail in tunes knocking like you wouldn't believe. These cars would have destroyed themselves had the tunes not been checked, diagnosed and adjusted on a dyno or the street. Most mail in tunes should be very conservative, but some arent, and the fact remains that you don't know what your cars engine is doing after the flash. Say your fuel pump is on the way out, and you flash a tune to your car that was developned on a car with everything working well. Say your injectors are a bit blocked etc etc. Your engine could be at risk of damage or indeed being damaged and you'd never know till it lets go. Hey, it's your money and it's your engine, if you want to risk it, by all means go for it. I prefer to know for sure my engine is safe.
    Tuners also allow a safety margin in their tuning, so that for example in higher ambient temps or fuel that is a couple of points down on octane rating, there is no knocking. You don't knife edge tune a street car like you would a drag or track car (these are often adjusted on the day of racing anyway to acount for variables). Also as engines wear sure things change, so you get a touch-up done after some time has passed, or if you change something like your exhaust.
  2. #32
    Sep 2010
    Melbourne, Victoria
    Lots of discussion here that isn't directly relevant to the r36 we're working on here but all good.
    I have several cars lined up for this tune in Melbourne. I will be logging and checking each car vigorously, as much as i am with the current car we're working on. I would like to think that modern cars are close enough out of the factory to run the exact same tune, but of course i will confirm that as well. Do keep in mind that these days the amount of loggable data is immense, to the point where you wouldn't even need a dyno other than to verify exact power gain to justify claimed power increase.
    Wideband o2, knock voltage, individual cylinder timing retard, etc. All at very fast sample rates via CAN bus.
    And, why would I reveal our tuning strategies behind this particular engine if it means other tuners will just do the same? I can obviously tell you we run more ign timing adjust the fuelling, but if that is too vague, then that is because we don't want to go revealing our secrets and losing customers to other tuners!
  3. #33
    Apr 2011
    I didn't want your in depth tuning method, that's obviously your information to keep, plus I understand how it's done anyway (I've not tuned an R36 but I'm not asking you to reveal the specific technical details of your tuning).
    When it comes down to it, all I was after is something simple like the following:
    KW at the wheels before tune =
    KW at the wheels after tune =
    Fuel used =
    Dyno used =
    Measurement mode used =
    EDIT: Engines may come of the factory line pretty close, but looking at oil consumption measurements after everyone runs in their engine and seeing how varied the results are, should indicate tolerances are not the same after use. Compression tests would reveal differences too. I've seen significant differences between same model/age with similar km vehicels. That's another discussion anyway. I'd just like you to post up some basic at the wheels power figures with dyno charts and dyno info to verify the claims.
  4. #34
    Jul 2010
    Quote Originally Posted by R36FTW View Post
    Of cause there will be cars that don't run well with a "mail in tune", depending on their state, my 1.8T had a blown coil pack after 500km of the tune, would that be the tune's fault or just extra stress put on an 8 yr old engine part?
    If your fuel pump dies/injector gets blocked etc, will a custom tune act differently to protect your engine? (genuine question as I've never tuned a car )
    I've run my 1.8T before and after on a dyno and the gains (reverse calculated) are inline with what the seller indicated.
    I know it's not on a dyno but I have also taken logs with VCDS after the tune (and every other things I put on just as a comparison) for timing, knock. airflow etc just to see if everything's fine.
    Am I the in minority if I say that I have had no problems with my "Mail in" tune so far?
    So again, that's where I (as an average Joe customer) wonder custom tuning a street car is that different to "Mail in" tunes. Most people don't want to get a touch up tune regularly (I can see the benefit in terms of maximising and maintaining the cars output).
    2008 Passat 3.2 Wagon |
    2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
  5. #35
    Mar 2009
    Perth WA
    I'm not that concerned about the peak power but the associated midrange increase and the promised throttle remapping to make the car feel a bit perkier. The R36 is not slow in reality but IMHO feels that way due mainly due to how the FBY throttle is calibrated.
    I drove the new A6 3.0S/C last weekend and with 5kW less than the R36 it felt a lot zippier down low when I selected the Dynamic mode which among other things changed the calibration of the throttle.
    2010 R36 Sedan
    2007 Audi A4 B7 Cabriolet
    1997 R33 GTR Skyline V-SPEC ,2011 Harley V-Rod Muscle
  6. #36
    Jul 2010
    Quote Originally Posted by R34 View Post
    Its prob more to do with the extra 70nm or so of torque from the forced induction than the throttle mapping I reckon.
  7. #37
    Mar 2009
    Perth WA
    Quote Originally Posted by johnw View Post
    Agreed
    Any more torque would help impove things
    Hope the next Passat R if it happens gets forced induction
    2010 R36 Sedan
  8. #38
    Apr 2011
    I agree with many of R36FTW's views on tuning as I also drive a modified jap car (mid 11sec GTR) but to say a mid 13 sec four door family saloon is not fast and not worth spending a cent on I disagree. Either way there is nothing wrong with wanting a few extra KW's and I have heard a lot of positive feedback regarding some of these mail order tunes, however I would never drive my R36 in anger with one of these tunes without first having it dynoed for piece of mind.
  9. #39
    Mar 2009
    Perth WA
    My GTR only manages 12's
    2010 R36 Sedan
  10. #40
    Apr 2011
    Nice, mines a silver R33 also,
    A set of GTSS turbos would fix that.
