Results 21 to 30 of 37
Thread: R36 Wagon RVC Install Questions
  1. #21
    Nov 2010
    I haven't run wires to the front yet. I haven't made it past the tailgate! I thought this would have been a simple job! I was also told to splice the two positives together and run them to the fuse in the back of the headunit but I am thinking that I should run the red positive to maybe the back of the headunit and the blue positive to the positive of the reversing light which is virtually right next to the camera. There also seems to be a ground point too right next to the camera but I am unsure on this for the time being.
    Here is the ebay ad I bought the kit
    Genuine Volkswagen Reverse Camera FOR Golf Wagon Passat Wagon Jetta AND Tiguan | eBay
    Her is a closer look at the problem child!
    R36 Wagon RVC Install Questions-image001-jpg
  2. #22
    Feb 2014
    Would it be any easier to start at the head unit and thread the other plug down the car to the camera?
  3. #23
    Jul 2013
    Hills District
    I think the seller is Vincent from Lane Cove, Sydney.
    Look at the second photo in his ebay listing, there is the blue plug and you did not get that?
  4. #24
    Nov 2010
    Nah, starting at the headunit doesn't solve the problem of how to get the wire through the rubber tube next to the tailgate hinge. The blue plug shown in the ad is on the cord coming off the camera itself. Hmm, i'm gonna have to get some professional help i think
  5. #25
    Aspendale, VIC
    The issue is the black plug, it should be blue. The blue one has a purple bit which easily unclips & disassembles the plastic leaving just the coaxle wire... You need to change this wire.
    2012 CS K04 GTI | GIAC | APR RSC 3" TBE | VWR Intake | KW V1 | OEM R Bi-xenons | OEM R Tails | Unibrace UB | S3 Intercooler | podi boost gauge | OSIR body kit | BBS CH
  6. #26
    Jul 2013
    Hills District
    ask seller for the tips and trick in the how to. he does installation as well.
  7. #27
    Nov 2010
    ok guys, this has been bugging me all night!! I rang a possible installer but the price was quite a lot out of my range so I contacted the seller again this morning and he has been good to deal with so I can highly recommend him. Vincent is his name too.
    He said to pull the big plug apart that attaches to the headunit. I was a little nervous about doing this but he assured me that it is what he does so I gave it a crack, and luckily, it worked, although it was a little bit of a bitch!! Hopefully I haven't buggered the contacts (which I think I didn't). Hopefully this will be small enough now to allow me to pull this end through the rubber tube near the hinge. If I can, then it will be onto the next issue of trying to get the wires through to the front of the car along the sill. I had a quick look and it doesn't look quite as simple as what I had hoped, but I'll give it a crack. Just gotta pick my timing right so I don't get in trouble for spending too much time with the car and not with our 11 month old.Well, here are some pics.
    R36 Wagon RVC Install Questions-image010-jpgR36 Wagon RVC Install Questions-image011-jpg
  8. #28
    Jul 2013
    Hills District
    good news, I did similar thing on desktop, trick is to use a small pin(paper clip thing) to undo the contacts. make sure the pin assignment is correct when you put them back.
    to get the cable to the headunit, a lot of panels need to be removed, interested in seeing how it goes. good luck mate!
  9. #29
    Nov 2010
    Yeah, I had a quick look at the amount of panels. There is a lot more than my trusty old XR8!
    Gonna have a crack after work today to see how I go. If I can get this through then I will be a little bit relieved, but not out of danger just yet.
    Can I ask one question though?
    Does any other wagon drivers have the RVC fitted as standard?
    I know the later models came with the RNS510 and satnav! I may be potentially the first with a RVC!
  10. #30
    Jul 2013
    Hills District
    not sure about 08 model but on 09/10 models, a lot come with RVC on either RNS510 or RCD510.
