I have no idea if this is even relevant, but an electrician trick is to use a rod (ie. fiberglass fishing pole), push that through the tight spot, tightly tape the cable/plug/whatever onto it and pull it back through.
Not sure what you're trying to thread through where, but I hope this info is useful somehow..
