Results 11 to 20 of 37
Thread: R36 Wagon RVC Install Questions
    Nov 2010
    Thanks mate but the issue is that the rubber is sort of right angles but the physical hole is not big enough. Gonna have to do some phoning around i think
    Jul 2013
    Hills District
    worth a read here?
    OEM backup camera installation for mk5-mk6 VW Golf hatch badge | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
    Run the coax and the red/white cable through the rubber pipe connecting the rear lid with the body work. It will just about fit, compress the rubber tube length to make it easier. The supplied red/white cable is not long enough to reach the rear boot lid and has to be joined after it exits the rubber tube, the join can be hidden behind the plastic trim that runs up the side of the window.
    R36 Wagon RVC Install Questions-golf-backup-camera-10-jpg
    Aspendale, VIC
    Oh now I know what you are referring to. To get it past the hole you have to take off the plastic bit & reassemble once it threaded through the rubber bit. The plastic bit is easy, just unclip & it falls away, thread the wire through & your done.
    2012 CS K04 GTI | GIAC | APR RSC 3" TBE | VWR Intake | KW V1 | OEM R Bi-xenons | OEM R Tails | Unibrace UB | S3 Intercooler | podi boost gauge | OSIR body kit | BBS CH
    Nov 2010
    Thanks mate. Thats the little sucker that i cant separate from the body to even have the chance. If here are some clips on the inside, it is near impossible to get fingers in there so that is where i am at
    Aspendale, VIC
    Check out the link that R36 Passat posted. There is a pic of how it looks when apart. "To get the coax cable through the trim and rubber pipe it’s necessary to remove the outer blue housing. The purple clip just pops off and the blue housing is held on by a clip. The coax connector only fits the housing one way round." I remember it's not that difficult...
    Nov 2010
    Yeah, the problem is that my coaxial cable doesnt have that outer sheath to remove. It is a one piece moulded section unlike the blue one in the link. That's part of my problem
    Aspendale, VIC
    So there isn't that purple clip which you can slide back & then releases the blue bit? Hmmm, not sure then is it a genuine cable?
    Nov 2010
    Not sure mate. The camera has the vw symbol and the cable has the proper pin to fit into the back of the headunit.
    Feb 2014
    Do you have a photo of the plug handy?
    Have you run the wiring to the headunit yet? I'm curious to know how difficult it is - I'm in the process of installing a subwooffa and am considering whether to tap the inputs at the amp or the head unit.
    Jul 2013
    Hills District
    A photo of the RVC kit will be helpful. Where did you buy the kit from?
