well done mate!
OK guys,
next on my list of LED upgrades is the licence plate. I was having a really good look around and I was quite shocked to see the prices of some of these items. Some upwards of $100. I found this site (1 Pair Error Free 3528 24 SMD LED License Plate Light SET FOR Audi TT Q5 A4 5 | eBay) which had them at $17.78 and decided to give it a go. Well I received the items yesterday and I was quite surprised. The quality was great. They were individually wrapped. Well, the next part was installing them. It looked simple but wasn't really until you know what you were doing. Well I did some searching online and eventually worked it out. I'll save you the hassle. All you do is get a decent sized flathead screwdriver and insert it in the slot on the face of the light that is already in the car. You then have to try and push it towards the opposite end of the light. I think that in all cases it should be to the right. Now, it is a little difficult and tough but you push right and at the same time, you try and pull it out. Maybe a small flathead under the same end as the slot you have the big screwdriver in, helps. You will work it out though as I did. Once the light assembly is free, unclip and replace with the new LED version. Simply reverse the process to install in the car again.
The LED's are quite bright compared to the dull yellow standard globes but it is certainly whiter and they match the same colour as my puddle lights which is great. Might have to look at some new parker globes as they seem too blue compared to all the others including the xenon headlights.
Anyhow, hope these pics help.
well done mate!
Looks great. Just tried ordering and the item says they don't ship to Australia. Did you have any issues? I have popped a question to the seller.
NickZ
Former ride: MY07 Black Polo GTI
Current: MY09 Blue Passat R36 Wagon
No mate. No problem whatsoever. If you do the correct word search you can find similar products for around the same price. Im surprised that there is a problem!
Figured it out, for some reason the mobile version said the product did not send to Australia but once I switched to the web version i could pay for it. Go figure!
NickZ
Ok mate. Good stuff
Bumping this thread up rather than creating a new one, I bought the exact listed items and they do not seem to fit my MY10.5 R36 wagon. I am thinking they might have changed the plugs between model years. I'll take a picture for you when it's daylight but the plug coming out of the car is bigger physically than the hole for the plug on the aftermarket LED module, although the pins are correct.
Just had another look at snerlo's pics, my factory light module looks physically a bit different from his. They have definitely revised the factory module with a different plug. I might see if I can cut the plastic surrounding the pins on the aftermarket module to make it fit.
I use the T10 W5W CANBUS error free LED bulbs I previously bought for the parkers, same effect, super easy and low cost.
That's my backup plan as well, I'll see how I go modding these, I have nothing to lose really if it doesn't work out.
Doesn't that sound just absolutely ridiculous that they would change the shape of the hole mid life in a car's cycle considering it is simply a light fitting. I can't believe it. Sorry mate. Didn't realise that they were different. Yeah, as Passat R36 has said, use a T10.
Just on that, my standard light that came out is a festoon type bulb!! Makes it even more weird that they would change the bulb type!!
