Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: R36 (wagon) fuel consumption
    May 2010
    Melbourne, VIC
    Quote Originally Posted by Felix View Post
    I have been using Shell. Reading some of the other posts BP is apparently the way to go, so I think I will be switching. Do you drive for longer periods? 70% of my trips are 5-10mins. As per Lance's comment above, I am wondering whether that is where I am getting it wrong?!
    The short drives certainly won't help. 5-10 minutes isn't long enough for the engine to get up to operating temp properly. Have you got any decent long driving trips coming up that involve significant highway miles? Maybe try taking a day trip somewhere on the weekend to see how the fuel economy goes? Where you fill up can certainly have an impact on fuel economy, but, barring anything unusual about the fuel, I suspect that how and where you use your car and your driving style will have a much bigger impact on the fuel economy.
    Once you've done a few tests for yourself, it should give you a better idea of why the fuel consumption is so high.
    Oh and on the first car bit, yes this one is my first. I always said I would wait until i could afford a Porsche. Then I got married and just had my first kid, so there went the Porsche and here is the R36. One day...
    Congrats on the newest addition to your family.
    Well, let's face it. The R36 is a lot more practical than the stereotypical Porsche.
    Nov 2008
    Sydney, Macquarie Park
    20l/100kms in a proper morning stop-start is about right, especially on the short runs. no idea why you need a heavy awd 3.6 litre car to drive 20mins a day but i guess you wanted a performance vehicle, so the thurst is the price you pay.
    anyway congrats on the purchase
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    Apr 2011
    I get around 15/L in heavy traffic. I've noticed though if you crawl along at around 10-20kmh the consumption is horrendous on the MFD, if you stop/start its better, which seems odd.
    I got 9.0L/100km when driving to Adelaide full highway with a pretty new engine (just over 1000 kms) and seem to get 11.5-12.5L/100km around town in free flowing traffic.
    Mar 2009
    Melbourne, Aus
    Felix
    If you are concerned about consumption, you may want to consider the following:
    (1) Record the kms (odometer) and litres added at each fill
    (2) Concurrently record the ave speed and ave consumption (#2 averages on the display) when you fill
    (3) Reset the averages
    With this data you can:
    (a) Correlate fuel consumption with average speed - over a number of tankfuls.
    (b) Check the calibration of the in-dash display.
    I do this and over 33000 kms on my R36 sedan I have:
    - Overall Average economy from tank fills = 13.2 lit/100kms
    - Overall Average economy from Trip Comp = 12.55 lit/100kms
    - Average of average speeds = 38.86 km/hr
    - Always fill with premium unleaded (9
    Unless there is something wrong with your car, some influences would be:
    * Driving Style
    * Traffic conditions and average speed.
    * Trip length
    * Tyre pressure
    FYI I live in North Fitzroy and commute to Port Melbourne every day. The engine temperature is up to normal within about 5 minutes, so a fair part of my driving is with the engine at operating temperature.
    My correlation of economy vs speed looks like this....
    Note my driving is generally 80% "sedate" and 20% "brisk"
    May 2010
    Melbourne, VIC
    Quote Originally Posted by Wolfman_36 View Post
    I never thought to record my average speeds per tank...what a good idea.
    What is your oil temp reading after that 5 minutes? I'm not convinced that the engine is at 'normal operating temperature' while the engine oil is still <50C (no reading on the oil temp readout). In my R36, the coolant temp is up to the middle of the dial within about 5 minutes from a cold start too, but the oil temp usually takes at least 10-12km before it gets up over 80C (stabilizes around 90C +/- 5C).
    Mar 2009
    Melbourne, Aus
    Quote Originally Posted by kleung View Post
    You got me there - I have never though to check oil temp. I had assumed that if the water was up to temp the block was warm and the mixture would be at normal operating AFR. I would be fascinated to see AFR vs temps (oil, water) from a cold start to see when it stabilised. I do not have the facility to log, but I am sure someone could do it via the OBD port.........
    May 2011
    kogarah
    wow, i applaud the scientific approach and the meticulous care you have taken. thanks for sharing
    Apr 2008
    NSW
    slightly off topic here..
    Would this figure be the same (more or less) for the sedan R36 as well? approx 400km per tank?
    And it would be the same too for the V6 Passat CC Im assuming?
    May 2010
    Melbourne, VIC
    Quote Originally Posted by stephen8512 View Post
    I'm not sure what to believe - the figures in the VW brochures don't really make a whole lot of sense logically:
    (from the 2010 CC/Passat brochures)
    Model
    R36 sedan
    R36 wagon
    CC V6
    Weight
    1681kg 1747kg 1656kg
    Combined economy
    10.0l/100km 9.9l/100km 10.5l/100km
    Urban cycle
    13.0/100km 13.6/100km 15.5/100km
    Extraurban cycle
    8.2/100km 7.7/100km 7.7/100km
    CO2 emissions
    233g 231g 254g
    So the heaviest car out of the three has the best overall fuel consumption, but the CC has taller gearing and weighs less than either R36 (and probably better aerodynamics) which should give it better overall fuel economy.
    Dec 2009
    Just adding to this thread as a new R36 wagon owner
    Getting around 500-550km's per tank as well and it ain't cheap to fill! I can't help but feel these things run insanely rich judging by the fuel consumption, colour of the exhaust tips and fuel smoke on WOT.
    If only there was a ECU flash to pull fueling out of the low/mid rev range, it would be a better car I think.
    Dino.
    SQ5 V6TDI | 911TT | Polo 6C
