At least the R36 drivetrain lives on in the V6 Highline, even if it doesn't have the same suspension, seats, or blue-needle instrumentation...
Congratulations!
Hah. Friday 13th. Hopefully that's not an omen. FWIW, Chinese consider the number 13 to be very lucky. Make sure you spend plenty of time exploring all the nooks and crannies on the road between Melbourne and Sydney. Don't forget the Beechworth Bakery!Pick it up Friday 13th - which is lucky for me. Drive from Melb to Sydney over two days which I'm looking forward to of course.
Considering that a Dynaudio factory audio upgrade is available, while using the same head units, I suspect that the RNS510 probably has line level outputs on the back, going to an outboard amp. If that's the case, it should be trivial to upgrade the speakers and amp. If not, the worst case is that you use line level converters to connect an aftermarket amp.Now just need to at some stage look to figure out how to undertake an upgrade of the standard stereo - keeping the sat nav system but building out amp and speakers (but that's my youth recollection talking).
It is possible to buy the MDI unit from eBay, and as I understand it, it is just plug and play into the existing cabling. $200-ish IIRC. I have the MDI in my R36, but I just have a 4gb USB flash disk permanently connected. CBF pulling my iPhone out each time I get in the car.I will need to figure out what to do to get my iPod to be able to be used via the RNS as the connection module (option I believe) does not come with the car -so pointers would be nice.
Given that you have a 30gb hard disk in the RNS510 already, using this may be a more convenient solution. Or if you don't like that, there's also the SD card reader - just pick up a cheap SD card from anywhere, and chuck your music on that. Just be aware though that older revisions of the RNS510 only support up to 2gb SD cards. Newer revisions support larger cards.
