Don't go there. I am abt 14mm out and the rubbing on full load is horrid going over bumps. I solved the fender rub by filing down the inside of part of the fender. Now, there is still minor rubbing against the carpet inside the wheel well. I just pushed in and glued some of the carpeting and all seems good now. Will have to monitor a bit more.
Do note there will be no fender rolling for the R36. If you need to change the wheels, I suggest to go out abt 10mm max.
