Originally Posted by
Timlin
Hiya
Have you bought your DynAudio amp yet?
If not, maybe a group buy could work...? I'm keen for one now - if its a plug & play situation.
Lemme know!
I haven't bought an amp yet, but will most likely buy this from Martin at www.JKU.com.au along with some speakers. When I was there the other day, he had a few amps in stock, so I'm sure he can supply them.
I'd like to figure out if it is plug and play also. Even if it requires some re-assignment of plug wires, that is ok too.
-- if you have the same inputs (4-channel, CAN-BUS, power, earth etc) and outputs (10 speakers), I don't see how it can't be made to work without having to re-wire
-- will also need to re-code with VCDS to tell the head-unit it's a Dynaudio amplifier (may require different level HU output)
Will post any findings to this thread. Hopefully someone who's already gone down this road can save us some time.
