Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: R36/Passat Wiper Issue
    Albany, WA
    Thanks revivor, will get it through the link provided.
    Bosch 980S Aerotwin Flat Windscreen Wiper Blades, Twin Pack 24 inch (600mm) & 19 inch (475mm)
    What about the OP, Mr Wolf I wonder what happened.
    Oct 2012
    Melbourne, Victoria
    Quote Originally Posted by sn809 View Post
    Hah, I've had a lot of my plate recently. Probably going to give Revivor's advice a whirl and see what happens.
    I have a feeling it'll still end up with me replacing something but we'll see how I go.
    Oct 2012
    Melbourne, Victoria
    Gave the car a wash today and decided to have a play with the wipers as per Revivor's advice. Turns out there's a spring within the wiper mechanism that's making an insane creaking sound.
    Now just thinking whether or not it's worth going through warranty to get it replaced.
    May 2012
    Sydney NSW
    Quote Originally Posted by MrWolf View Post
    You may want to try some WD-40 (or equivalent) first - have found that it can make a big difference in such situations (suggest that you use the little tube so that you do not get it everywhere).
    Aus
    My opinion would be to get it fixed under warranty. WD40 would only go so far! The spring is not a common wear & tear part as far as I'm aware. ie. its not supposed to make that noise so early in its life.
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
    May 2012
    Sydney NSW
    Quote Originally Posted by revivor View Post
    Fully agree with revivor - WD40 is only a temporary measure (to make it livable/less annoying until you fix it). If the car is under warranty, go and let the VW service people have the pleasure of listening to the noise . . .
    Oct 2012
    Melbourne, Victoria
    Cheers for the advice guys. Will look into it.
