Thanks for the writeup. How are they after a few weeks? Do they feel solid and not like they're going to fall off?
Installed some paddleshift extenders this morning. I've held off on doing this as they can look tacky - these are well built and suit the OEM brushed Aluminium look (also found it annoying trying to find the small factory shifters sometimes):
Here's the ebay link: Steering Wheel DSG Paddle Extension FIT VW MK6 Golf GTI R Scirocco R20 R36 CC | eBay
(a little off-topic..) Also added some carbon fiber to the custom subwooffa box and removed it from the mold - (my boot is now back to normal!):
BTW - the carbon fiber on this part of the enclosure is for strength and doesn't have to look pretty.. only the top layer/sheet will be visible.
They're still on there solid and I have no desire to remove them (it's still just tape, so not perfect).
I've found myself using them a lot more now - they make me drive bad.
Ideally, I'd epoxy them in place if I had a spare pair of OEM shifters I was happy to destroy (and was comfortable pulling them in/out).
