Results 1 to 3 of 3
Thread: R36 Paddleshift Extensions
    Feb 2014
    Installed some paddleshift extenders this morning. I've held off on doing this as they can look tacky - these are well built and suit the OEM brushed Aluminium look (also found it annoying trying to find the small factory shifters sometimes):
    R36 Paddleshift Extensions-20140524_082600-jpg R36 Paddleshift Extensions-20140524_083807-jpg
    Here's the ebay link: Steering Wheel DSG Paddle Extension FIT VW MK6 Golf GTI R Scirocco R20 R36 CC | eBay
    (a little off-topic..) Also added some carbon fiber to the custom subwooffa box and removed it from the mold - (my boot is now back to normal!):
    BTW - the carbon fiber on this part of the enclosure is for strength and doesn't have to look pretty.. only the top layer/sheet will be visible.
    R36 Paddleshift Extensions-20140521_204739-jpg R36 Paddleshift Extensions-20140523_203310-jpg R36 Paddleshift Extensions-20140523_204529-jpg
    Apr 2014
    Thanks for the writeup. How are they after a few weeks? Do they feel solid and not like they're going to fall off?
    Feb 2014
    They're still on there solid and I have no desire to remove them (it's still just tape, so not perfect).
    I've found myself using them a lot more now - they make me drive bad.
    Ideally, I'd epoxy them in place if I had a spare pair of OEM shifters I was happy to destroy (and was comfortable pulling them in/out).
