Originally Posted by
Radius
There are a few ongoing small things that have surfaced though. The first is a loud grinding noise from the front left corner when reversing at low speed while on brakes. It reminds me of a similar issue we had with a near-new Mazda 3 which turned out to be a faulty wheel hub
Has anyone else had this prob and what did it turn out to be? Anything that needs a specific repair?
The second is a significant amount of creaking from interior when passing obliquely over inclined driveways back onto the road. Basically sounds like all those nice trim bits in the interior are rubbing against each other at the same time, especially around the mid-cabin at the 2nd pillars. I'm assuming this is all caused to chassis flex.... but its something we don't get in our Jetta when passing the same obstacles and aren't these two chassis' very related underneath? How much of this is actually normal? Incidentally I've also got rattles from every direction of the interior when passing bumps.... and I thought the Jetta already had enough of them!
Apart from that, loving the car!
Hi Radius,
Good to hear you enjoying the car.
I suggest you get the front wheel checked with the Dealer asap, in case something is wrong, you don't want to find out the hard way!
As of interior creaking, I haven't noticed any in my car and there are quite a few speed bumps. A friend has quite a steep driveway and nothing there either.
I haven't really helped you I guess, good luck though and hope these issues will be resolved soon.
R36 Wagon, blue, sunroof, towbar, auto tailgate, MDI, and now with upgraded sound system
1969 TL1600 Fastback
Suzuki GSX1400, Yamaha XVS1100 Bobber
....fairings are for scooters!
