Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: R36 Lights
    Apr 2011
    R36 Lights
    Got sick of looking at the standard yellow corning lights so have just replaced with Phillips Crystal Vision. Colour now matches the Xenons. Has anyone replaced the parkers and puddle lights, if so what have you used and is it a simple swap? With the puddle lights , does the plastic just clip off or does the mirror need to be dismantled?
    ---------- Post added at 06:25 PM ---------- Previous post was at 12:07 AM ----------
    For those that are interested to remove the parkers simply pull on the flat plastic tab. This can be located by following the two wires that seem to disappear in the headlight behind the cover. Haven't figured out the puddle lights yet, hopefully the lens just pops out with a screw driver. Will give it a go tonight.
    Dec 2009
    Hi mate,
    Very keen to do this as the yellow cornering lights are NOT cool Which Crystal visions did you use? part no.?
    Yes, puddle lamp replaced with a square 4 SMD down firing board, the lamp cover simple unclips.
    Parkers done also by pulling on the plastic tab, but one has started to flicker so will be ordering a another pair.
    I also didn't like that the LED parkers seemed quite 'blue' in comparison, so would like to try and find a more 'clean' white that matches the Xenons.
    Dino.
    SQ5 V6TDI | 911TT | Polo 6C
    Sydney,NSW
    Can you guys pls post some instructions on how to change the cornering lights as I too would like to match the xenons on my b7 passat and also the puddle lights.
    Much appreciated in advance guys.
    Apr 2011
    Cornering lights used are Crystal Vision H7. They match the Xenons quite well. They simply pull straight out. They also came with parking globes. These are a little whiter than the OEM ones but are still yellow in comparison to the Xenons. Let us know if you find a good matching parking bulb. Do the LED parkers have the built in resistor and does it make installing it a problem?.
    Sydney,NSW
    Managed to pull the fog lights out pretty straight forward but delicate. The bulbs are both H8
    Apr 2011
    PASHN8 where did you buy the LED's from? Are they available locally or do you recommend an online store.
    ---------- Post added at 08:06 PM ---------- Previous post was at 03:09 PM ----------
    Having trouble removing the lens cover off the puddle lights seems to be glued on. Any advice would be greatly appreciated.
    Sep 2005
    Maroubra Beach
    Quote Originally Posted by R36 DSG View Post
    He bought them from me I may have an extra set let me check.
    Cheers,
    Costa...
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
    Apr 2011
    The puddle light lens cover DOES NOT simply clip off, found this out the hard way. i.e broken lens. Found out that if you push the mirror forward there's a small torx screw that presumably holds the lens in place. Off to VW to order a new lens. $80! Sheesh!
    Sep 2005
    Maroubra Beach
    mine were clipped in as well pretty sure
    Apr 2011
    Unless the 08's are different.
