Isnt the RCD510 the standard head unit...? It is pretty easy to self install. All you need is some torx drivers to unscrew the four bolts that hold the head unit in...
Pretty sure there are some DIY guides on the Passat forum of VW Vortex which will show you how easy it is to get the dash apart ..
