Results 1 to 10 of 16
Thread: R36 factory tint
    R36 factory tint
    I just bought a R36 from QLD and took it to be ID inspected in SA. Unfortunately I'm told that the tint is too dark and it needs to be removed. The seller tells me that the tint is factory from VW - does anyone know if that matters? Should I try and get some supporting evidence from VW?
    Sep 2006
    VW's do have factory tinted glass. You can you usually tell as only the rear window and rear passenger windows are tinted.
    Problems can be if more tint is applied to the rear (over the top of the VW tint) which will make it over the limit for darkness. fronts do not get the dark tint from factory and should be lighter.
    Both my Amarok and old CC Passat had factory tint, whereas my R36 did not get it (weird though). It may be part of an option i.e. comfort package?
    Darks
    Quote Originally Posted by RRR036 View Post
    Mine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
    Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
    Erskineville, NSW
    If it's factory tint then the only way to remove it is to replace the glass. I assume they (Regency??) are knocking back anything rear of the b-pillar?
    If it's either of the two front windows then it isn't factory tint - just a film.
    Ring VW Customer Assist.
    Also, throw it back at the inspector & ask them to show you the relevant legislation regarding window tint.
    SA regs
    Your allowed 35% on all side & rear windows.
    Chassis and body modifications - Government of South Australia
    http://www.sa.gov.au/upload/franchis...es%2011.13.pdf
    Also, they keep referring to a coating but factory privacy tint isn't a coating, its embedded in the glass (body tint) and there is no reference to VLT of body tint in the documents I've seen.
    Yeah I'm thinking that it is a factory option that was fitted by VW in QLD.
    TransportSA claim that it is 25% all round. Definitely the front windows are too dark, but the rears I am not so sure. I too thought it would be privacy glass, but it seems as though it is a film (can see the silver bits around the edge of the window).
    Sep 2006
    factory fit is not the same as a dealer fitted option.
    if the fronts are dark then it has an aftermarket tint pure and simple. the only real way to counter balance the rear tints is to only have after market tint of the two front windows.
    Erskineville, NSW
    Not the same thing.
    You'll have to get it stripped. Tint people can do it easy enough
    Cheers lads. Can't believe VW didn't supply them with privacy glass...
    Sent from my HTC One X using Tapatalk
    Mar 2009
    I got defected for factory tint on my wagon had to take over Regency then got vw to replace so be careful
    Dec 2012
    adelaide, south australia
    Welcome to the r36 club congrats. Keep us informed on how u get on. Hope to u see on the adelaide cruises and coffee meets
    Quote Originally Posted by levendi001 View Post
    Thanks man. Keen to check out some other cars and what you guys have done with them.
