Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: R36 exhaust tip
    Dec 2012
    adelaide, south australia
    If u want retail go to sprints its 25.00 a bottle very pricey. Check out car care products.com.au for the einszett wheel cleaner around 18.00.i used iron x diluted at 50% however sonax will give just as good as result
    Erskineville, NSW
    CCP are the place to go. Always good, informed service. They used to give a discount to VWwc members - not sure if that's still the case.
    Levendi - where can I find out how to use Iron-X. I've got a bottle at home & don't quite know what the best usage is.
    Feb 2010
    South Perth, WA
    I used a non stick pot scourer pad and turpentine on my R36 exhaust tips worked a treat and no scratching!
    WLF127
    Dec 2012
    Brad check inbox pm sent
    Erskineville, NSW
    thx levendi
    Shakespeare. I think our idea of no scratches might be different to others. Pot scourer pad & turps (or kero) would work for me too
    Nov 2010
    Camira
    R36 exhaust  tip-1909330_344192299046261_1027399930_o-jpg
    Got my R36 Detailed the other weekend. Turned out amazing!!! And the biggest shock was how easy the tailpipes where to clean.
    Rising Blue MY10 Passat R36
    BLACK '97 Mk3 GL 2.0L
    White '82 MK1 Cabrio 1.8L
    Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
    Nov 2010
    Camira
    R36 exhaust  tip-1965449_344192209046270_181634625_o-jpg
    Here is a before and after shot
    Nov 2010
    Camira
    Using this product to clean them.
    Car Care Products / Einszett 1Z / Exterior / Wheel Cleaners / ColourTec Wheel Cleaner
    Jan 2014
    Como
    ive found that just a simple non stick scotchbrite pad & maguires car wash does the job pretty well.
    Maybe if that doesnt work to your liking try it with some fine stainless steel polish like the type you get from dept stores for high end stainless steel pots & pans. I think esteele make a powder that you mix with water that is great for stainless kitchen wear that should work
