Quote Originally Posted by maclean_cherry View Post
Thanks Ryan and Tigger. So from that thread it looks like I tick an additional box and the other ones should already be ticked?
Found a thread with someone in Canberra offering VCDS cable to borrow so I've hit them up for that.
Thanks again.
MC
Exactly. There should be a single check box that needs to be ticked. Fairly easy to check.
If it's already ticked then it'll go onto stage 2 investigation - pull out airbag and check wiring connections. But you may want to get someone else do it for you as airbags aren't something you want to "play" with. If they go off it can be fatal.
