Results 21 to 30 of 39
Thread: R36 Climate control
  1. #21
    Dec 2008
    Melbourne, VIC
    Quote Originally Posted by R34 View Post
    Yeah
    Auto with one light illuminated is the low auto option correct?
    R34,
    From memory the left light illuminated on AUTO button indicates LOW Auto option and right light illuminated indicates HIGH Auto option. Again, refer to user manual.
  2. #22
    Dec 2008
    Melbourne, VIC
    Quote Originally Posted by Dr Block View Post
    I picked my R36 up last Wednesday, Rocket...only 3 temp settings for the front heated seats.
    Rocket36 is correct, in the MY09 R36 (older style Climate Control) it had a dial with 6 temperature settings, whereas the new MY10 R36 climate control has only 3 temperature settings (push on temperature dial).
  3. #23
    May 2009
    My aircon is also very ordinary and does what others have posted. Frankly it's not good enough for a car at this price.
    Particularly annoying now that we're in the middle of winter here in Qld (the outside temp is hitting in the low 20's !!!!!!)
    As to the new air-con controls versus the MY09? IMO they're terrible and a step backwards for sure (my Golf has this "new" climate controller and the "old" R36 one is much better to use)
    Thankfully the Golf also displays the temp around the control knob so I won't lose temp display when I lose the Rcd (I assume it's the same on the MY10 R36? dual displays?)
    Mini Cooper S Chilli- when I can pry the keys
    Carbon Steel GTi 19" BE by Breyton,LED tail lights, NEW 8" Nav !
    Facelift Daytona Grey A5 Sportback, S-line 19" Titanium Rotors
  4. #24
    Dec 2008
    Melbourne, VIC
    Quote Originally Posted by GHW View Post
    Yes the MY10 R36 has the dual display (temperature around temperature dial and also RCD when any settings is changed).
    Again, MY09 R36 temperature dial had increments of 0.5 degree whereas MY10 R36 has 1 degree increments. So people who are not sure whether they would like 19 or 20 degrees can opt for 19.5 degrees in the MY09 R36 climate control.
  5. #25
    Apr 2009
    Melbourne, VIC
    Quote Originally Posted by zsolt_downunder View Post
    plus other minor refinements over the MY09 R36 that i have noticed
    Please elaborate. I'm not saying things haven't improved as I would expect minor improvements all the time from (even slightly) newer models. But I'm just curious what refinements you're referring to from and already exceptionally well refined car.
  6. #26
    Jul 2009
    Templestowe, Victoria
    Hi ZSolt,
    As I am expecting a MY10 R36, I am curious to know what are the other minor refinements?
  7. #27
    Dec 2008
    Melbourne, VIC
    Rocket36/Szikou,
    here is some of the changes i have noticed from MY09 to MY10:
    Under-tray has channels cut out for directing air at brakes
    Wheel arch plastic cover has cut out for additional cooling of brakes
    Brake calipers seems to be different (actually different shape)
    Different climate control fully integrated with RCD510 : not sure whether this is really a refinement
    MFD has additional Oil Temperature
  8. #28
    Jul 2009
    Thanks ZSolt.
    It appears that these changes are improvement uprgades rather than cost cutting changes.
  9. #29
    Apr 2009
    Melbourne, VIC
    Brake cooling is cool. I'd call it an improvement rather than a refinement though. How many pots are the new calipers though? That's the important part. I LOVE the stopping power by the way...
    HVAC controls aren't a refinement at all... More like a step backwards as there is LESS features! I also use my HVAC temp display in engineering mode for more accurate road speed than the speedo.
    Oil temp is already accessable on my car.
  10. #30
    May 2009
    Quote Originally Posted by Rocket36 View Post
    Please explain...
    Pete
    MY13 Octavia vRS TDI DSG
