Results 11 to 20 of 38
Thread: R36 Audio upgrade
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by Swallowtail View Post
    Yes, works fine... Northfield at Moorooka did mine. We've actually tweaked the balance / fader a bit so it's more setup for me as the driver than the rest of the car.
    It's a fairly small amp too size-wise (but not in oomph!)
    The upgrade looks worth all the initial order-issues . Well done getting a great solution with the dealer!
    Did you mean biasing balance toward the left and fader to the front? I tried out both the Dynaudio and standard systems before settling my order. Speaker placements the same in both.... found that both systems seemed very side-dependent ie. in the driver's seat sound stage seemed to come predominantly from the right front corner.... things improved somewhat with re-balancing toward the front-left. Did you have the same issues post-upgrade or did you find an inherent improvement?
    And since you've had the opportunity to see the OEM equipment - was the standard speakers / amp of any quality? Did it indicate who's the manufacturer?
    MY10 R36 Wagon Icelandic Grey
    Jetta MY08 2.0FSI Reflex Silver
    Jun 2009
    Ok, now for the review of the Swallowtails upgraded audio system.
    Firstly, a huge thanks to Swallowtail, it was great to catch up this morning and compare notes. He has certainly done a huge amount of reading and research into add on bits, and using the existing items to their full potentional.
    The sound system...
    The upgraded sounded system is a significant improvement over the stock system. If you are into audio in any decent form, its money worth spending (something else I need to buy now ) The overall image is much much cleaner, their is a very nice clarity right across the range. I was expecting just the top end to be much more detailed however even the bass is very detailed without being too obtrusive. On one track we played there was a bass guitar that came in mid track and it was perfectly placed in the sound stage, easily disguishable but not overpowering. The is more than enough proper bass and there is no need for any subwoofer, not even in the slightest!
    He also showed me the MDI interface, works brilliantly with the iphone preserving all the playlists etc and duplicating ipod menu options in the phone. If you need that connectivity, again a worthwhile option, although it wouldnt be the top of my list as the capacility on the HDD would be sufficient for my music selection.
    The other part we played with internally was the Fiscon BT upgrade that he had installed himself. Again, this is a worthwhile upgrade, especially if you are on the phone in the car with any regularity. The syncing with the phone allows the system to fully realise its potential by giving you full integration with your contacts etc both on the centre screen and the in the dash. This will be also on my shopping list (It was an expensive visit and I am not finished yet!!)
    We also discussed the different features of the sat nav unit and Swallowtail has found a way of importing POI's into the system that works brilliantly
    Lastly, I also checked out the towbar install on the car. when standings at the rear of the car (with the tongue remove) you cant even tell the car has the capacity for one. This was sorta on my shopping list at the time but I held off as a) I hadnt seen it in the flesh and b) didnt want to pay the LCT on it with the new purchase. But now definitely will be done at first service. (if not sooner)
    So... all in all, a great visit and nice to meet one of our new moderators! thanks again.
    <Now.... towbar $1800, fiscon $800, Sound upgrade $3000... looks like i need to start saving!!>
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
    Feb 2009
    Thanks Apom, and ditto - good to meet you too.
    First to answer radius' questions -
    1. Yes, I have the balance / fader set slightly to front left. Places things much better for the driver. And as I am the only one who really cranks it up then that's fine!
    2. The stock stuff is Blaupunkt, and it looks and feels crap. The speakers are lightweight and flimsy, and the amp is small and puny... but if anyone wants to buy them let me know...
    Apom, thank you for your kind comments... glad you enjoyed! I will burn a copy of the Nav DVD (that you already own ) with those extra POIs as discussed. I am happy with the sound upgrade, planning on giving it a good workout over the next few weeks!
    I'll have to see if I can try to use the towbar and see if it works to plan. Be interesting to see if it's been wired properly so that the rear parking sensors disable when the trailer is on.
    One thing with seeing Apom's wagon - it's a hot looking car the R36 wagon. VERY nice... Got to be one of the best looking wagon's on the road I reckon. And the auto tailgate is uber-cool...
    Unfortunately my car was filthy this morning so we didn't do photos (cleaned it this afternoon). Next time...
    Jun 2009
    Melbourne, VIC
    Thanks heaps for your info Swallowtail! And glad to hear apom's wagon looks good too =) Now I just can't wait for mine to arrive. Cheers!
    Feb 2008
    Sydney, Australia
    Swallowtail,
    All sounds very good (pun intended)
    Did they have the amp in stock?
    I am thinking of going the same route as you, can you advise how they connected the amp up to the main deck and speakers? The reason I ask is that some of the original equipment amps in these cars need the output of the deck and their output to the speakers is already split into low/mid/high.
    Feb 2009
    Yes they had the amp in stock.
    There is a device called an LC6i (http://caraudiosecurity.com/shop/pro...s_id/3867.html) between the head unit and the amp.
    Works fine...
    Feb 2008
    Sydney, Australia
    Thanks for the heads-up, Swallowtail.
    I shall inform my installer.
    May 2009
    Hey Swallowtail, it's great to hear you're happy with your system, I was very impressed (I got to listen to it literally just after the passenger seat was bolted back in )
    Drew and I were both commenting on the imaging and staging, tight punchy accurate bass and the biggest improvement, the top end. I must admit it was better than I was expecting ( and I'm pretty fussy apparently) then I had to get back into my car and listen to the stocker (but not for long, I just booked mine in for next week, can't wait!)
    Mini Cooper S Chilli- when I can pry the keys
    Carbon Steel GTi 19" BE by Breyton,LED tail lights, NEW 8" Nav !
    Facelift Daytona Grey A5 Sportback, S-line 19" Titanium Rotors
    Jul 2009
    Sounds like you've ended up with a nice audio set-up in the end Swallowtail. Would you say it compares favourably with the Dynaudio system?
    Feb 2009
    Quote Originally Posted by Benem View Post
    I didn't hear the Dynaudio... I ordered it unheard cos I didn't like the stock system. For the cost of it it should be as good...
    GHW - have you heard the Dynaudio?
