Results 1 to 10 of 15
Thread: R36 Air con
    Jun 2009
    R36 Air con
    Hi all,
    Had the R36 for about 7 weeks now and not sure if I have an issue with the Air con. Only used it a hand full of times(the air con that is) but did use it again today. It took AGES for the car to cool down. I've just come from a 08 WRX and that Air con was very effective and cooled the car down in minutes. Today it took at least 5 minutes and on Full fan speed until the car eventually cooled down .
    Any thoughts from other R36 or passat drivers on the effectiveness of the Air con.
    Peter
    2008 WRX 153 KW
    2001 WRX
    1998 WRX
    Feb 2009
    How hot is it outside in Adelaide? I have no problems with the AC on mine up here in QLD...
    Jun 2009
    It was 22 in the car after being in the sun for about half an hour.
    2008 WRX 153 KW
    2001 WRX
    1998 WRX
    Jun 2009
    ahhh.... interesting..same problem here.
    I would check out your temp gauge at idle to see if it starts to increase with the air on OR if the air cuts out after 5 minutes.
    This is exactly what my car was doing and on the w/e it seems to have caused issues with overheating. The jury is still out to as if the 2 were related but check out my thread on R36 overheating!
    Gone...........R36 Icelandic Gray Wagon
    Specialising in off-topic discussion
    Feb 2009
    Lewiston South Austrlia
    Quote Originally Posted by weasel View Post
    Hi all,
    Peter
    Peter, I had an issue with the aircon in my R36 Wagon in January this year. The aircon couldn't make up its mind whether to blow hot or cold air, btw the outside temp was over 40. Eventually the fault (apparently not uncommon in VW V6's) was diagnosed as a blocked TX valve. The solution in my case was to replace the compressor. In the short term I found that by switching it on and off a couple of times sometimes works. cheers pj
    Jun 2009
    check if the fan is cutting in when the car is hot. If there is no air blowing over the compressor the thing shuts itself down. Just had this problem diagnosed today as the problem with my overheating R36
    Jun 2009
    Booked it in on Friday to get it looked at, will let you all know the outcome then. Also asked them to find the annoying squeek at the rear seats somewhere. Drives me crazy every time I drive over rough roads or drains/driveways.
    Peter
    2008 WRX 153 KW
    2001 WRX
    1998 WRX
    Dec 2007
    Brisbane, Southside...
    I don't understand why people don't just use air con all the time. Especially when you've got climate control, just put the temperature on 24 and you're all good unless it's super hot and then you drop it right down.
    Of course if you're going to give it some stick then turn it off to save some kW for the wheels.
    Hope you get it sorted.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Feb 2009
    I actually prefer driving with windows or sunroof open - I can hear the glorious V6 noise better when I do LOL... and it saves a fair bit of fuel, although that is a minor consideration. I live in Queensland, the weather is brilliant - I like to enjoy it not always be stuck in artificially cooled air.
    Dec 2007
    Quote Originally Posted by Swallowtail View Post
    I do enjoy this too but for normal motoring you get annoying wind noise and you end up with a dusty interior.
    Cheers,
    Trent
