Not a peep out of mine.
Are your doors adjusted properly?
Guys,
When driving over an uneven surface such as entering a service station driveway at an angle (where driverway meets road) the door seals around the car are squeaking, presumably caused by the vehicle body flexing.
I've never heard/noticed this in previous cars with stiffened suspension such as Liberty GT. Do others experience noticable squeaking with their R36's? (R36 10.5 Wagon, 6,000ks)
Cheers,
Paul
2010 R36 Sedan
2007 Audi A4 B7 Cabriolet
1997 R33 GTR Skyline V-SPEC ,2011 Harley V-Rod Muscle
yep, mine has done it from the start....no biggie
The R36 body is apparently is one of the most rigid/tight chassis around. I can hear my chassis flex everytime i go up my driveway on an angle. Shouldn't be a problem should it?
On that of that, since yours is a wagon, i suppose you have a longer chassis than the sedan version which already has a long wheel base. You should hear more flexing as you go up slopes at an angle.
This is a lift from a previous post on the Golf Forum. It may help.
Fixing creaking door seals
From reading this thread there seems to be two issues. The B pillar clicking and the door seal creaking. The door seal creaking drove me insane on my GTI MkVI and I was also very disappointed that such an expensive German car would have this fault.
I tried Dupont Krytox, it works for a month then needs (a very messy) top up. Don't bother with it. I bought Gummi Pflege (from WaxIt, Melb) and after 3 applications on all door seals right around the car, no more creaking from any of them!! The car is blissfully silent and it has lasted 4 months now.
I have also finally been able to polish out my messy door frames and this didn't make the creaking in the rubbers return. Hope the fix works for those of you with the creaking door seals. Don't be sucked into buying Krytox from VW at $70 a tube - it will cost you that much every quarter.....
You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
mine does this as well. Never thought much of it because it will generally only do it when going up a fairly steep driveway/doing crazy angles so it won't scrape...
Pete
MY13 Octavia vRS TDI DSG
Phew. Sounds like the squeaking is a common occurrence - hopefully this amount of flex is within design tolerances. I personally would have thought the amount of flex required to cause a squished rubber door seal to overcome friction and slide against the frame to cause squeaking would have meant too much flex...
Cheers.
Phew!!! Glad I found this thread. My R36 sedan (9,000km) started seriously creaking about 2 weeks ago exact at described, B pillar, and door seals sounds like around the C pillar as well. And now I hear it every time there is a transition in the road or some times on take off or stops when there is weight transfer from front to back or vice verser. It was getting really worried about chassis flex. I get the seals lubed and see what happens. Cheers.
MY10 Black R36 sedan
the silent assasin
