Anyone know of an after market proxy key / push button start mod available for a 2011 wagon?
BMW call it comfort access, and google only comes up with ones in the states.
I'm technologishmaly illiterate, so would need have someone do the install.
Thanks in advance!
many thanks, il check it out!
I think you might have a bit of an issue regarding the immobilliser. The car isn't going to start without the key reader around the ignition seeing a coded key.
You probably need to do a KESSY retrofit... I've seen a Dynaudio speaker set that actually included the door cable looms for KESSY retrofit, just need some guru to do the VCDS recoding magic...
=> everything is possible if you are obsessive enough
.:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
