Results 1 to 7 of 7
Thread: Problem RCD 500 in Passat,Battery flat HELP
    Feb 2006
    Hi there
    hope somebody will help
    Afther instaling 2 months old RCD 510 in my wifes passat 2007( suplied with pin code) afther 2 days battery went flat.replace with second hand battery thinking battery gone,and again afther few days again same story, cant crank att all.
    got another battery from working car, 4 days afther same story...again
    Next day bought BRAND NEW (good one) baterry and second day battery flat.again ...FFF....so it i think must be 100% RCD problem or do I need to go to the dealer or... dont have clue....
    Did I need to code somethin or...
    Thanks
    Oli
    any body need good second hand batterys???
    Cheap
    Last edited by Oli; 30-10-2009 at 02:07 PM. Reason: NEW UNIT IS RCD 510,the old unit was 500
    Feb 2009
    I think there are some issues with using the newer radios on cars with older CAN BUS controllers. You may need to upgrade that... THere are a lot of posts around (not just in here) about these issues, but I am not knowledgeable enough on the subject to be able to definitively state that is the issue...
    Feb 2006
    Yes it could be problem somewhere there...
    I do have curent vag com but dont know what i need to do( or do i need ) do i need some coding to be done in can bus or in the radio...
    Feb 2009
    Using your VAGCOM find out the part number of your CANBUS controller (Controller 19 I think)...
    Feb 2006
    Talking
    Problem solved...in the head, now just need to be done on the car..
    Thanks everyone
    Oli
    Feb 2008
    Outer East - Melbourne
    Quote Originally Posted by Oli View Post
    Thanks everyone
    Oli
    and the solution was.....
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
    Feb 2006
    Talking can bus GATE WAY is to old ,need new version
    Sorry I thought it was posted here
    guy h send me some very helpfull info,everything is there even more then I need..
    http://www.my-gti.com/1101/upgrading...er-drain-issue
    Oli
