Quote Originally Posted by reverseworm View Post
yeah simple to use for sure after you take the time to work it out - turn it to the left, the roof opens. turn it to the right and it closes. in terms of pros and cons, in my view, this is one of the few cons. good controls should be completely intuitive - unless you are inspector gadget you simply cannot see exactly the point you need to turn it to to close the roof. and i dont want to be counting clicks either. no biggie but a con for me nonetheless.
Blacky will need to make the decision for himself, but every other sunroof I have had is far simpler and it aint a deal breaker anyway.
and right next to the sunroof control is the worlds smallest sunglass holder. so that is another con, but the flip side pro is that it is great for pens
So I checked mine out last night.. half right, half wrong.. the sunroof indicator mark on dial is illuminated, but the surround isn't..
It's pretty easy, if pointed straight ahead, then the roof's closed, if turned to the left then slides open proportionally to how far it's turned, if turned to the right then tilts proportionally. I've never had a problem with it, and no complaints from anyone else who's used the car, once they've worked out or been told how to use it.
