Results 11 to 20 of 23
Thread: Poor Performance with Conti Sport 3's
    Queensland, Australia
    Don't forget to inflate your tyre pressures to 4psi more than recommended - good for fuel economy and mileage.
    Tony.
    2008 Passat 125TDI DSG, Leather.
    2007 MkV Golf GTI - APR, 188kW, Leather, Manual.
    Jul 2009
    Templestowe, Victoria
    Hi Guys,
    Besides the Dealer, can somebody please recommend a good place in Melbourne for a Wheel Alignment in Melbourne?
    Thanks
    2010 R36 BB Wagon - With the Lot
    Jan 2009
    blankedy
    Any tyre shop should be able to do an alignment, let them know up front you want a printout
    Jul 2009
    Thanks Noone, but I have heard to stay away from Tyre Shops and rather seek a suspension specialist.
    Has anybody taken their R36 for a wheel alignment and been impressed with the service?
    Erskineville, NSW
    Ralf at TrueTrack.
    It has nothing to do with the shop & everything to do with the operator.
    Noone - you are right. Any tyre shop can do an alignment to factory specs but a good wheel aligner will set the car up to compensate for driving style & how the tyres actually wear. I used to set up old 450 SEL Mercs & Taragos so far away from factory specs it scared me sometimes - customers were happy though.
    Mar 2008
    Melbournes Inner North
    what brad said...ralph or zac at trutrack.....they did mine when i took delivery....
    Jul 2009
    Thanks guys.
    I read online that Trutrack are supposed to be very good. Will give them a call
    Trutrack Car Suspension Melbourne | Car Suspension | Melbourne Dynamic Wheel Balancing
    Feb 2010
    Nebo
    V6Passat - thanks for your advice.. i might take that up one day when i buy myslef a nice tan set of Hush Puppies and a cardigan to match.
    Nebo1
    Dec 2009
    Blacktown,NSW
    Quote Originally Posted by Nebo1 View Post
    Don't forget to wear your lawn bowls hat when you're driving as well.
    MY10 R36 Wagon Biscay Blue|Satnav|Bluetooth|Sunroof|Auto Tailgate|Adaptive Cruise Control| - First Time VW Owner
    Jan 2010
    North Shore
    Was the Right front worse? If so, there's probably a bit of a toe-out issue.
    How does a toe issue cause more wear on one tyre than the other on the same axle?
    To the OP: Make sure you get a 4 wheel alignment not just a front alignment. The front wheels are aligned off the rear so if your rear is out then your front is out.
    As for longer wearing tyres, all tyres have wear rating on the side. The lower the number the less life you will get out of them. High performance tyres generally range between 100 and 300. Anything higher than that will generally be an all purpose tyre.
    Also be careful of finding deals on tyres. I had a customer during the week that had found Continentals for $280 each. There are a few manufacturers that have manufacturing facilities in countries like Malaysia and Indonesia. The tyres are marked the same but the rubber used to make them is inferior. I'm sure Michelin is another one like that which is shame as Michelin are (IMO) the best tyres.
