Originally Posted by
Rob Burns
How does a toe issue cause more wear on one tyre than the other on the same axle?
camber of the road. For RHD counries, if you don't give them a fraction more -ve on the left to compensate for the road camber then you have to "steer" up the camber of the road. If you have toe-out then the RH wheel tends to wear a bit more on the inside; toe-in & the LH wears a bit more on the outside.
