Originally Posted by
anthony
Its boot is actually bigger than the Passats.
Where did you get that from
Jetta boot = 527 litres, 1160mm long, 1364mm max width and 1009mm between wheel arches.
Passat boot = 565 litres, 1164mm long, 1412mm max width and 1014mm between wheel arches.
The Passat is bigger EVERY WHERE except weight. Jetta with TDI = 1540kg, Passat with TDI = 1526kg, and the Passat TDI has heaps more power / torque output available (until they make the upgraded TDI available in the Jetta)
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
