Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: passat tiptronic servicing
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Diesel_vert View Post
    Are you sure?
    The 09G gearbox (Aisin TF-60SN) specifies G 055 025 A2 (Esso/Mobil ATF 3309 or Toyota ATF Type T-IV), which is dyed red.
    The 01M gearbox (4-speed) specifies G 052 162 A2 (Esso/Mobil ATF LT 71141), which is dyed yellow.
    Yes, you are correct.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Erskineville, NSW
    Red + green = brown.
    Assume the usual remaining red ATF in the torque converter, mixed with some Castrol Transmax Z that is (apparently) dyed green.
    That was before the Transmax. That chocolatey crap is pure Dexron 2 or 3
    Erskineville, NSW
    Quote Originally Posted by passat08 View Post
    Ok and what would be a ball park figure I would be paying a don't really want to go through vw to do, also what is the definate part numbers and what need exactly? Cheers
    Best ask your local mobile VW tech.
    May 2010
    Melbourne, VIC
    I have a 2008 passat tfsi have been told that these transmissions don't need servicing it is the tiptronic gearbox can anyone shed some light on this please?
    I have a copy of the 2008 Passat Technical Specifications brochure, and according to that, you are correct - the 2008 2.0T 147TSI petrol is fitted with a conventional torque converter auto, not a DSG. But it still needs regular servicing just like every other conventional car gearbox.
