I had the exact same thing happen - was quoted $450 for a new fob/cutting/programming - Pulled the remote apart, then some delicate cutting of the white plastic to get to the button side - found the switch that makes contact with the button, had cracked solder joint. Quick resolder on all legs.. did the other two for good measure - All working now
- You may not post replies
- You may not edit your posts
Forum Rules
